ford drop-in bed liner - removal/adjustment
Truck2
jeff
usa
toyota highlander hybrid
How hard is it to take off the left and right side panels of the drop-in bed liner? I need to remove each side to drill a hole so I can add the screws so I can use an old 05 ford sport trac bed extender, using the Ford screws part # w707381-s900
thank you
Cubican
Pedro
Ridgeline, viper, c8
Is a 10 minute job there is one screw on each side then use prybar to lift the bottom to get them off the channel
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
Depends on what packages you have. If you just have a base XL or XLT/Lariat there isn't much to do. If you have extra cubbies, tie downs and the bed rails it might take a little longer.
bluesteel
Jerry
Bergland, MI (U.P.)
2022 Maverick Lariat
Very easy once tie downs and any other attachments are removed
