FORD brand tailgate liner question
Wingman54
ANDREW
South Carolina
2024 Maverick XLT FX4
My new Ford-brand tailgate liner arrived today; Ford Part # NZ6Z-9900038-C.
So, it appears to mount utilizing the (8) TORX screws that fasten a cover plate(?) to the inside face of the tailgate.
Question, does this cover plate need to be removed and does the liner go right into that vacated space, or is it merely attached directly over top of the tail gate (without removing this cover plate)?
If it just mounts over top of tailgate, I'm not sure the TORX screws are going to be long enough (without removing them).
Has anyone installed one of these?
Thanks in advance!
Ranch
Sacramento CA
2023 Marverick FX4 4K
Thanks in advance!
I installed one and it goes on top of the tailgate. The provided screws worked fine.
Mike1597
Western Kentucky
2025 Maverick Lariat AWD, 2024 Mustang Mach-E, 2024 Ford Edge
When I installed mine, I just used the provided screws and installed over the tailgate. The only thing I wasn't sure of was where to use the provided pieces of sticky tape.
Wingman54
ANDREW
South Carolina
Sticky Tape?? None was supplied with mine.
DG2
Dan
Boston North Shore
2025 Maverick XLT 2022 Mach E GT
I just installed mine yesterday. The sticky tape goes over the 4 outside holes before you put the liner on. I was able to get directions on the web site see attached
RookieBlue7
Georgia
Maverick XL
Since there were no instructions, I just guessed where to apply the rubber peel off things.
They’re contact patches. Basically put them where the cover contacts the paint to keep from vibrating and creating a scuffed spot
