I was told by Ford Marketing, that it is up to the Dealer, if they will accept the Transition Private Offer and the Farm Bureau offerthe fine print says it can't be used "with most Ford Motor Company private incentives or AXZD-plans" so I am assuming it is an either or situation.
Hi YB98, did you ever get confirmation if the FB certificate can be combined with the Transition Private offer.ill pm you
same here and signed up 1/7![]()
Anyone getting this error? I signed up for IL farm bureau 1/13 and have an id and associate member showing active.
i had the same problem, If you take the "-" out it should work, at least that is what worked for me.same here and signed up 1/7
Yup same. I signed up for IL however I live in FL. I put my FL address when I signed up and am using that zip code but I don't think that's what's causing it.tried that also, no good
You do have to be a member for 30 days before you can use it. I am not sure if that is why its not working.tried that also, no good
You have to be a member for 30 days before u can get ur certificate. My situation was I joined FB on 11/30 and for some reason they didn’t consider me a member till 12/15. So 1/15 I was able to get and print my certificate.![]()
