Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
2022 XL Ford Maverick
The DD setup uses a realy And fuse and ground. My setup its straight from the bcm to the front fog lights. But im going to start adding fuse next to the bcm for safety reasson just in case. I had my setup for almost 2 years i think i still havent had any issues with blown fuses or wire malfunctions.
WA
2024 Maverick XLT Hybrid
Fuse shouldn’t be needed. If over draw occurred the FET would trip and be reset next power cycle.
FWIW on my 350, I’m driving two Baja Squadron Pros off the factory foglight connectors and they are well under budget amps wise. The BCM is the relay in this case.
great write up btw! Just picked up a 24 XLT and I’ll be doing this soon.
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
Thanks .
TXM2
Houston
2022 FWD ECO Maverick Lariat Lux
Hi @Vtech87pr1, great tutorial. I had purchased and installed my DD fog light kit but was a little disappointment at the switch it comes with and was hesitant to install it. And then I came across your post and I can't describe my excitement. Right away I went online and ordered the switch and the leads for the BCM connector. I'm currently performing the install and ran into not being able to unlatch the BCM connector from the fuse panel. Is there a trick to it? I tried pushing the lever but won't budge. Help! :). Below is a snip of your own picture with markings on the latch I refer to.
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 1709934519980
In the middle of the lever there's that latch you need to push and then you can pull back on the lever.
TXM2
Houston
Got it! Thanks.
Will be posting pictures soon as that is probably the part I consider the hardest so far. I'm very handy and comfortable around car electronics but I was panicking of thinking I could break that assembly and cause myself a bigger headache.
Thanks again.
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
Got it! Thanks.
Thanks again.
yes sorry i was busy working
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
Hi to the ppl that are interested on my harness i will need to know what type of fog lights your using. Im going to start sending them with open ends so you have enough to cut or splice your own conectors. Please let me know here whos interested .
list :
@A.Bursell
@710-oil-614
@IHateSpeedbumps
@Yanks4285
IHateSpeedbumps
Nick
Central Texas
I am very interested. I would be doing the diode dynamics kit.
Yanks4285
Edward
Cape Coral
21 BMW X5,08 Pontiac G8,15 Chevy SS, 23 BMW M3
I’m for sure down. I’ll be doing the Diode Dynamics kit as well.
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
Im looking for volunteers of anyone that buys the harness i want to make a video on how to do it your self and i will install it for free. Right now im lacking materials so it will take time.
IHateSpeedbumps
Nick
Central Texas
If you were closer I would definitely take you up on it.
710-oil-614
Cal
2025 Hybrid AWD Lariat
100% buying a harness and pretty interested in being your volunteer. Would just need to plan it with you as I'd be coming over from Ohio.
I will also be using Diode Dynamics (SSC1 Pods) - this kit specifically with the Tremor bezels and brackets:
https://jjc-llc.com/products/copy-of-2023-ford-maverick-tremor-2-fog-light-mounting-kit
EDIT: Also already have my F-150 fog light switch.
CurtisB
2023 Maverick XLT Hybrid
Sounds like a great opportunity. Please be one of those that make the videos with a "stationary videos frame concept". The constant shaking, tilting and moving around type videos can be hard to follow. One doesn't need to hold a camera in one hand while moving around to the front of the truck then bend over into the engine compartment, then keep holding the camera while crawling underneath.............you get my drift. I actually don't watch those type of videos and search for the ones where you don't get sea sick. LoL. Just me!
