EPA uses E0 gas for testing
mamboman777
Josh
NRH, TX
STARCOMMTREY1
Trey
Boligee, AL
Remember.....rules for thee not for me
olderbudwiser
Yup, worked many years in Ford emission area. Not only non ethanol but high octane. I do not recall the number but all vehicles tested used same fuel. Regardless if it required regular or premium.
710-oil-614
Cal
2025 Hybrid AWD Lariat
Not surprising I guess. However I would think a manufacturers minimum recommended fuel grade is what would be tested.
olderbudwiser
I should be careful here as it was many years ago and procedures change.
dceggert
Metro Detroit
2017 Fusion, 2019 Ranger, 2024 Maverick ordered
91 Research Octane Number (RON). That is the research number though. Remember that when buying fuel at a pump it may be labeled 87, 89, or 91 but that is the (R+M)/2 number. The "91 RON" is the "R" in the above equation.
The research grade fuel is used to make all the FE numbers on all gasoline vehicles equivalent. If 'pump' fuel were to be used it would be all over the map for results. You could end up with a V8 Silverado getting better FE than a Ranger Ecoboost due to shenanigans manipulating the test fuel or just some stroke of luck that one vehicle got some bad fuel on test day.
Also, it is important to point out that the FE number is NOT just to provide guidance to the customer it is used to rate the manufacturers fleet FE, provide a basis for corporate taxation, and to allow direct vehicle to vehicle comparisons with a common baseline.
olderbudwiser
On occasion a prototype configuration would come through with instruction to run vehicle fuel. Back then I wondered why.
In later years different job discovered at APG we could mix our own fuel as there were times we would take a vehicle to the fuel lab and have 100 + non ethanol put in the vehicle.
Snax
North America
STARCOMMTREY1
Trey
Boligee, AL
STARCOMMTREY1
Trey
Boligee, AL
Arukoru
Atlanta
2013 Chevy Cruze
Maybe this is a state by state thing but I can buy zero ethanol fuel here in Georgia just to address a couple rules for thee and not for me comments.
Additionally worth mentioning I think that it is probably easier to just have 1 fuel type and you're basically guaranteed to only need one fuel type with e0 premium.
edit: also I should mention that the EPA doesn't test gas mileage for consumer advocacy it does so to verify emissions standards are being met so if we're being really technical this doesn't matter at all.
Snax
North America
And the rules for thee not for me is NOT a jab at any particular group but the entire fed govt as a whole.
You just can’t resist any opportunity to insert your politics into discussions, can you?
atomguy245
Doug
The EPA has a methodology for doing the fuel economy testing, but then original results get "massaged" before the numbers are put on the window sticker, in an effort to make them more realistic And the numbers on the window sticker are not the number the automaker have to use to meet their CAFE fuel economy requirements. The numbers the automakers are held to are more lenient. It's a complicated mess
wjg
William
Mustang, Maverick
https://www.pure-gas.org/extensions/maps.jsp?statecode=ALL
Might find this helpful.
