Edit: Steelies Can Actually Look Good!
Drew
Drew
Drew
Maverick Transit Prius Honda Yamaha Chevy
No doubt that steelies can look good with the proper tire on it. Throw some KO2s and those steelies will look solid!
I agree. I’ll do that on my next one. I’m selling this one.
Drew
Drew
Drew
I would mask off and paint the 3 hole sets in black (Just the area between them) times 5. Then you will have the look similar to the Chevy Rally wheels. pinstripe contrasting color around if you'd Like. See crude job below for the general idea.
Interesting…
LSchicago
Lloyd
IL
Interesting…
Here's another way to paint the wheels to make them not look like steelies from a distance. These look more like 70's turbine wheels. (again sorry for the crude rendering)
Ford Maverick Edit: Steelies Can Actually Look Good! s-l5002
Drew
Drew
Drew
Wow, I would’ve never thought of that.
LSchicago
Lloyd
IL
LSchicago
Lloyd
IL
I would make so many errors trying to do that.
My compliments to the ones able to pull that off!
Just need the correct width Making tape. I would leave the edge silver though.
austinzone
Tampa
Honda Element
they look nice but are a $1000 for a set…
while I like the grenadine wheel my worry would be that it would look small because of the black lip.
but maybe im wronk
Drew
Drew
Drew
but maybe im wronk
I like that wheel. Uncluttered.
MavJeff
Old Hickory TN
F-100
The standard 17-inch steel wheels are so anti-style that they circle back to be stylish.
I saw this write up somewhere & saved it to my quotes page. Purchsed a set of Bronco wheels last weekend, no hurry to install them..
jaf58
Manahawkin, NJ
2022 Maverick XL
Steel wheels only way to go. Chunck into a pot hole with alluminum and there goes the rim. Steel just hammer it back and inflate. I'd go with chrome moon caps but no tabs to lock them on.
Did you remove the center caps to put the wheel covers on?
MavJeff
Old Hickory TN
F-100
I bought these Escape wheels with with 245/70R17... I like 'em, but the offset as it is will not work
Ford Maverick Edit: Steelies Can Actually Look Good! 20221021_162122
Ford Maverick Edit: Steelies Can Actually Look Good! 20221021_162202
MavJeff
Old Hickory TN
F-100
These wheels are 7.5 instead of 7...and I forget the offset, but the net is 21mm! If I shim that much, won't be enough thread for the lug, imho.
I slapped these on in the interrum...
Ford Maverick Edit: Steelies Can Actually Look Good! 20221021_165234
Ford Maverick Edit: Steelies Can Actually Look Good! 20221021_165249
