- First Name
- Mike
- May 3, 2024
- KC Metro area
- 2005 Toyota RAV4, 2024 XLT Hybrid
- Engine
- 2.5L Hybrid
Yes well aware of how it works - questions were to see if you did, since many try things that aren't useful in the end.you know how you are driving in EV mode and the box around your activity gets smaller and smaller. thats your HV battery being used. when it gets too small it will not go back to EV mode...it goes from Hybrid to Charging and the engine stays on.. Clicking the L button will max out the recharge fast and slow you down without brake lights.. it also seems to reset the 2 outer lines of the box and i can use EV mode like normal again. i never really "coast", i am always fiddling with the gas/go pedal to max out the lines to the edge of the box without turning the engine on. i can work it in EVin the high 60s.![]()
no never ever attempt to get back up to speed in EV mode only, that would take way too much time.
So for you to get any meaningful regen out of L mode you'd have to slow down more than a bit, or be on decent hill to overcome the strongest regen and not terribly slow down - doing that on highway got my attention.
Happens faster there obviously, when it can be done.
HVB will be allowed to get down to 30% before ICE turns on to recharge to minimum 40%.
Your regen attempts will get it to max of 70%.
As long as it's above 30% and the power request isn't too high (abouts 15% for your 25), the ICE will not be used.
Some speeds are slower at allowing the ICE to charge the HVB, because the generator motor is also dialing in the gearing required - especially highway speeds.
Coasting is really going to give the best MPG of course, no ICE running, no HVB used, some regen to charge it - and distance covered.
Closer you keep to that - the closer to best.
So regenning down to a slower speed that requires speed up, with no benefit of recharging while ICE is running - isn't close. Almost sounds like what you are doing.
Just caught my eye as interesting way of trying to get the charge back up, by regen and slowing.
