Thanks for the tip!
Confirm what gas grade, tonneau cover or mud flaps you use.I only use ECO mode. I’m on track to get 850+ miles on this tank.
Regen is black & white, I actually measured the regen in each mode.It would be nice to know if ECO mode (my preferred mode) provides adjustments to Variable Valve Timing to (further) increase the efficiency of the Atkinson cycle.
So far, this forum seems to regard ECO and slippery modes as adjustments to regeneration. While this is obviously true, it may not be all that is going on. My longer drives still seem more efficient in ECO. Increased coasting from slippery mode, wouldn't seem to match my results.
I think I might becoming a slippery mode convert. Tyger and I ha a day trip which included winding roads, switchbacks and hills on the way up and hills and interstate on the way back. I chose eco mode for the way up, about 45 miles and slippery for the way back. I obviously went a lot slower with the winding curves and thought I would get fantastic mpg and ended up with around 47 mpg (which is still pretty darn good). On the way back I ran the interstate most of the way averaging right at 70 mph in slippery and I averaged 53.5 mpg! Went faster and got better mpg, I like it! I’m going to keep experimenting until I do the long road trip in a couple weeks. Eco or SlipperyRegen is black & white, I actually measured the regen in each mode.
It is certain that Eco has stronger regen than normal with a full lift off the go pedal, and slippery has less strong regen when you lift off the go pedal.
The amount of power (watt-hours) you can generate are the same in any mode.
Eco will slow you down to 3 mph in 1/8 of a mile and put 10% charge into the battery.
Under the same conditions Normal will slow you down in 1/4 of a mile and put 10% charge into the battery.
Under the same conditions, Slippery will slow you down in 3/8 of a mile and put 10% charge into the battery.
That much is known. Why do I prefer Slippery?
In Eco my engine is off for 1/8 of a mile while I coast.
In Slippery my engine is off for 3/8 of a mile while I coast.
I have a tool to measure timing.
I'll look into that next.
you too? welcome to my world. as far as my darling Bride is concerned those mode buttons may as well not exist..... sigh.That would seem to be logical...except you get the best efficiency in slippery mode in most circumstances.
Doesn't bother me, but I have noticed that my wife never bothers switching the modes (no matter how many times I say something).
