Must you be stopped to switch drive modes? Could not find answer in manual or in searches. Thanks for help in advance. 2024 AWD LXT w/Luxury package and 4K towing package
All the modes are just "software/settings" based, so no physical changes are happening when you change modes. Just the software settings that control things like the throttle response, etc... Totally fine to change drive mode going 80 on the freeway. But if you do, you might realize you need to step harder on the accelerator when going from something like Sport mode to Slippery mode. Ha!Must you be stopped to switch drive modes? Could not find answer in manual or in searches. Thanks for help in advance. 2024 AWD LXT w/Luxury package and 4K towing package
yes to this, especially when towingBest to do with little or no throttle
yes, you might even need to put it in reverse before switching modes.Must you be stopped to switch drive modes? Could not find answer in manual or in searches. Thanks for help in advance. 2024 AWD LXT w/Luxury package and 4K towing package
totally wrong information!yes, you might even need to put it in reverse before switching modes.
Also not the seller.If you search on ebay for "MY MAVE MODE" you will find a very easy to install kit that will automatically put your truck into ECO Mode every time you start it. I have one installed and it works great. Now I just start my truck and within seconds it is automatically put into ECO Mode. I just drive away after starting. Worth the $39 or $49 USD depending on if you have remote start on your Key. Make sure you order the correct one as they are slightly different in how they connect. You can still manually select other Modes as required or very easily reprogram it to select any other Mode as default at startup. I have nothing to do with whoever it is that sells them.....Just a satisfied end user.
That search does not work well. I just get a bunch of Ranger items. Any other info needed?Also not the seller.
search on e-bay should be for: My Mav MODE
Device is solid state so no relay noises.
One word, no spaces.That search does not work well. I just get a bunch of Ranger items. Any other info needed?
sorry for my errorOne word, no spaces.
https://www.ebay.com/itm/275967879719
