Drain hole for tonneau?
CACTI_HYBRID
Rick
Meridian, ID
2022 Ford Maverick XL Hybrid
I installed my undercover ultraflex tonneau cover without too much difficulty. I used the holes in each side at the front of the bed to run the drain tubes. I'm not sure however where these hole s lead to and if this is an appropriate spot to let water drain into. Does anyone know for sure?
Ford Maverick Drain hole for tonneau? 20230606_102249_HDR
WhiteMaverick12
Andrew
Tennessee
2022 Maverick XL, AWD
I ended up drilling a hole in the center of my tonneau cover and then a hole directly under that in the bed of the truck. Now it drains in a place similar to the AC.
CACTI_HYBRID
CACTI_HYBRID
Rick
Meridian, ID
I'd really not want to have to drill any holes in the truck. These holes seem perfectly positioned for how I'd like to use them so as long as they don't drain into some interior panel, I just as soon stick with them.
Rolmav
Kansas City
2025 Maverick
They should just drain in the wheel well to the ground. If you get underneath you should be able to see them poking through.
Far as I know those drain to the ground, mine was installed by cover mfg rep and that’s where they installed drain lines
