Downshifting delay
Slops
Sterling Va
24 Maverick Tremor
Anyone else annoyed at the delay from the time you hit the gas pedal to downshifting? I had the same thing in my edge sport. Dangerously slow reaction time when you’re trying to make a move.
Vtec87pr1
Antonio
Virginia
youtube.com
2022 XL Ford Maverick
Sounds like you need paddle shifters lol just messing with you. Normal all cars automatic and turbo takes a little time to downshift.
AutobahnSHO
Will
S.Carolina
Maverick, Miata
Sounds like every car with Automatic transmission I've ever driven....
AlsMaverick
Allen
Cincinnati
2024 Maverick Lariat FX4 w/4k Tow Build Date 12/5
Older transmissions with a solid kick-down linkage could be adjusted for near immediate downshift. There are some things about old technology that I miss.
However, I bet you could find a tuner that knows how o adjust the kick0down response.
dalola
Retired
SE Ohio 🇺🇸
The issue is amplified with the 8,9,10 speed AT's everyone is using now. When the ECM calls for a rapid downshift, there are more gears & algorithms to sort through before the hardware kicks in.
Generally, if you're in a lower gear, the down shift is quicker. But if you're cruising along in (8-9-10) at 50-60 mph, then suddenly go to WOT, that will require more time for the ECM to sort out.
Waterick
Richard
Laurens county SC
Not the one I grew up on, my 389 Pontiac/Turbo-Hydramatic was quick, even at 70 and would hold that downshift past 90 (never checked how far past).
Edit: of course the fuel economy did leave a bit to be desired.
fossil
ernie
ohio
yep, that's one of the things sport mode does,
Slops
Slops
Sterling Va
24 Maverick Tremor
Keep it in Sport mode if it bothers you that much or grab a tune from Cobb or Livernois.
No sport mode on the tremor. I’ve been thinking about tuning it but don’t want to break shit and void my warranty.
710-oil-614
Cal
2025 Hybrid AWD Lariat
Sport mode can be added via Forscan and it won't void your warranty. Sport mode definitely wakes up the Tremor a bit.
Slops
Slops
Sterling Va
24 Maverick Tremor
Awesome. Thanks. So I need an adapter and a laptop for that?
Slops
Slops
Sterling Va
24 Maverick Tremor
24 is too new. Waiting for forscan to add it then send me the test build. Did you do it on yours?
