2026 XLT 2.0 EB non B&O.
Just installed the 10” Kicker Hideaway behind the rear seat. I’m using the DC offset signal sense for turn on. I have the high level inputs connected to the rear speaker wires but I disconnected the rear speakers when I did this as I don’t want to use them. I did set the EQ to flat in Forscan.
First time powering everything up the sub would not turn on. The power light just kept slowly flashing red. I switched it to 12v turn on and jumped the remote wire to the 12v+ and it came right on. Put it back to DC offset and the next time I tried it it came on and worked fine.
So I’m wondering if not having the speakers connected was causing the issue maybe the ACM thinking no speakers connected and shutting off the output? Or maybe something wrong with the HS10? I’ll see if it happens any more but if load resistors might be needed I’ll go ahead and add them.
