why do the rear speakers sound so tinny
Longhorn
northern arizona
2023 ford maverick xlt ecoboost AWD FX4 LUX
2023 XLT fx4 LUX
i’m curious if they have built in bass reduction in the speaker itself or the factory eq or both
Carlitos_92
There is definitely high-pass filtering programmed into the system that can be removed.
Unfortunately they are small, cheap speakers mounted with zero enclosure, so there is just not that much potential there, even with replacing the speakers outright.
squirlz
Madison, WI
2025 Maverick XLT Hybrid AWD
They have aggressive high pass filters. They can be disabled in FORScan, you can set the rears to Speaker and tweeter instead of Tweeter Only. This will lower the the high pass. I would only do this if you replace the rear speakers.
Non B&O Measurements
Longhorn
Longhorn
northern arizona
thank you for the tip! i have plans to replace the rear speakers with KICKER 4 inch speakers
