Do I need load generators?
tturby
Todd
Missouri
2025 Ford Maverick XLT, 2023 Mustang Mach E GT
I installed an AudioControl A110.5 5 channel amp in my 2025 Maverick non B&O. When setting the gains, only a 1/4 turn from 0 is way to much on my Kicker KS series speakers. Do I need to install load generators? It seems like the factory stereo is trying to compensate for something and sending way to much power or a very distorted signal. I just got my o scope and am getting ready to test the signal from the stereo for distortion but was wondering if anyone has encountered this.
Wahjahbvious
Don't Worry About It
Erf
'26 Hybrid Lariat in a color that seems to anger the dumbest people you know
What's your input level set to?
Unless I misunderstand (totally possible) you're sending an amplified signal - rather than a preamp signal - into an amplifier.
scharris99
Daytona Beach
2025 Maverick XLT
You are adjusting the gain. There is no reason to turn it to any certain position. Optimally, put a scope on it & turn the head unit up until it clips/distorts, then back off a little, now set your gain on the amp to where the amp clips/distorts and back that off a little. You have now set your system for maximum signal to noise. You then know that any distortion you hear below your known max is either the speakers or the source.
tturby
Todd
Missouri
Non amplified radio other than the head unit power from the OEM system into the line level inputs on the amp which can handle up to 20V. I've read that on some newer systems, if the factory head unit does not see a load on it, it can send messed up signal through the speaker wires to compensate for a blown speaker.
