DIY REMOVABLE FLEX BED KAYAK RACK
Longhorn
northern arizona
2023 ford maverick xlt ecoboost AWD FX4 LUX
Just wanted to show you all the kayak ( removable ) rack I built with 1 5/8 " Galvanized Unistrut Rack . I put both my 12'6" kayaks on rack and worked great!
i like your idea better it looks safer than hanging mine so far out
sunglint
Wayne
Houston
2022 Hybrid
I would love to get more details on this. It looks like you're using the DIY unistrut rail solution, but I also see cross braces. And is this suspended on the rails? I would think you would need the legs to extend down to the bed, to an interface that takes the load and protects the bed from wear. Wood or plastic with rubber would probably work for that. Great work!
fcooney7316
Francis
Windsor NY
2025 Maverick XLT
Hello , I will make up a list of what I used and lights if you want
Pequa1
Art
NY
2010 Ranger
Too old and short to use an over the cab rack since I yak alone. Get the bow up on rear crosspiece and just walk forward.
Ford Maverick DIY REMOVABLE FLEX BED KAYAK RACK IMG_2993
MavStangVa
Here, There, and Everywhere
2024 LARIAT AWD
Did you ever put together a parts list? I'm particularly interested in cross rails that can attach to the Ford flexbed rails.
fcooney7316
Francis
Windsor NY
2025 Maverick XLT
Hello , 1 -10' length os 1 5:8" Stainless unistrut( for m6 maverick tapped bed rails) 5 lengths x10' of 1 5/8" galvanized strut, 12- 1 5/8 90degree 4 hole angle clips and 50- 3/8" X 1 1/4" cap screws, 50-3:8" flat washers and 50- 3/8" unistrut nuts. Hope this helps.
MavStangVa
2024 LARIAT AWD
Thanks
Timothyd
I love Unistrut and that rack works but a hitch mounted rack is sooo easy.
I'd take your rack, make it 2' longer and you'd have a sleeper!
