pawalsh610
Paul
Aurora, CO
Hybrid Maverick 1st Edition Lariat, Mazda 2
Great application of thinking outside the box. I like your color choice but now that you have planted the seed I going to give some thought to other colors that might work with my Lariet interior.
REDROOSTER
REDROOSTER
2025 Maverick Hybrid XLT
I do want to warn everyone….clean the areas really well before sticking. The first section I did I don’t clean it and it started to peel the next day. The areas I cleaned really well worked out much better. They had a minimal peeling and I was able to rub them down
Cancunbadlands
Cancun
Cancun
jonshep
SW Oklahoma
I don't know if this was worth the time you put into the project, but man you did a really nice job fitting the fabrick. It should protect what you covered and it looks fantastic..
REDROOSTER
REDROOSTER
Thanks. All in it only took a little over an hour. Most of the time was spent making templates out of butcher paper….. the areas where the seat belts hit are tricky as they angle up toward the back with a small flat so I had to redo the template a couple of times.
JMJB
Fresno California
'22 VB XLT Hybrid with Sunroof
...and what was used to properly clean the plastics before attaching the fabric ?
REDROOSTER
REDROOSTER
I used a very small amount of 70% rubbing alcohol. Time will tell if it all stays attached but after a couple of days it still appears okay
REDROOSTER
REDROOSTER
After I did all this I found some precut protectors for the doors on Amazon. While I was at it, I tried to find something for where the seat belts scratch and I couldn’t locate anything. That said, I did find some silicone covers that go over the seatbelt for $5 that will probably prevent the scratches.
DesertSandTremor
Nick
Delray Beach, Florida
25 Desert Sand Maverick Tremor, 25 Space White F150 Raptor 37
FWIW....Adhesion is definitely a challenge with the low energy plastics Ford used. When I did the vinyl wrap on my dash, I used 3M adhesion promoter to help. It made the surface tacky and I haven't had any issues a year later with the vinyl coming up on the dash.
Adhesion promoter - https://a.co/d/hUvoQsf
3M article and white papers - https://www.3m.com/3M/en_US/bonding-and-assembly-us/applications/material-bonding/lse-plastics/
REDROOSTER
REDROOSTER
Very good advice. The plastic is a challenge. If mine comes off I will likely take your advice. Thanks!
RebellaE
Dallas, TX
2022 Maverick XLT, Lux, 360
I'd love to hear an update after the fabric has been through a summer. I'd love to cover a few of the most scratch prone spots, but I fear the adhesive would just melt and give out in the Texas heat.
