NickyB
Nick
KCMO
23 XLT
Do you have any pictures of the truck with it off? Wondering how it looks removed all together.
Barracuda340
Abilene Tx
I do not. Truck is silver, so I may just spray some flat black paint inside the fender vent hole so silver cant be seen through the honeycomb screen
jdmancus
North East Pennsylvania
Ford Maverick LARIAT AWD, 97 Toyota 4 Runner
FIrst post here and a nod to @jewc75, and I am sure a few others, for inspiration and instructions. Got my Mav a week ago. Had a full year to think about this modification. The side badge disturbed me as a black piece of non functioning plastic stuck on the fender.
- Sanded only the "XLT"to give it the brushed look, sand in one direction. Did not sand anything else or use primer. The paint is from R&E Paint Supply in Mountain Home, AR. They offer most if not all of the Maverick colors. I think it is a perfect match and reasonably priced. https://repaintsupply.com/​
-Stripes are pinstripe tape from AutoZone​
-After painting I chipped paint off the "XLT" with light touch on a razor blade. It flaked right off from lack of primer. Did not want to use sand paper to avoid hitting good paint. The paint is definitely stuck to the black plastic. I then added the stripes and applied Dupli-color gloss clear coat from AutoZone​
-Light is a three wire LED from Amazon- Partsam 2pcs 3/4" Mini Amber LED Marker Clearance Light Turn Signal Light Air Dam Lights, 3 Wires, 12V. The light has two intensities, the brighter I wired for the turn signal. Drill a 3/4" hole in badge.​
-Lens is from GadCad at Etsy. Stuck on with 3M tape. Was concerned with how well it would seal so I drilled a small hole at the bottom point for drainage just in case.​
-Wired it by tapping all three wires into the front running/turn signal lights. Yellow/black on drivers side is turn signal, blue/white on passenger side. Definitely use black cloth tape to wrap/re-wrap wires.​
- Badge is a lot easier/safer to reinstall if you take the metal clips out of the fender and slide them on the tabs on the badge prior to reinstall.​
I am pleased with the results and now have a more visible side turn signal.
Nice Job!!!!!!
Montauk
Brit
2024 Maverick XL, 2023 F-150 Rattler pkg
What it looks like behind the vent. I will be painting this area flat black with rattle can.
Thanks for sharing this. Knowing where and what fasteners are behind there is helpful. (y)
uh50
Howard
www.hchaney.com
2022 Maverick XL, VB, 2.0 EB
Simple and Classy. Great work!
White Thunder
Donald
Sapulpa, Oklahoma
2022 Maverick XL
I really like that.
HSBII
Sam
2017 Super Duty 2024 Maverick
This is the route I am going. The LED strip will be hidden behind the fender vent honeycomb grille. These I plan on wiring up as turn signals. Everything is just fitted and mocked up. Will start with gluing the screens in tomorrow
Did you ever finish these emblems they look great on the bench but how about on your truck would also like to know how you removed the plastic to add the mesh…
Toddman45
St. Louis, MO
That is a thing of beauty and looks like something that came stock on the Maverick.
