Disable horn beep when locking doors?
Shakesbear
J. R.
Luke..... believe me, im retired Military, i can take alot ... 🤣
Because, if it is different... and does something different to the settings of the truck, don't you think it would be beneficial?
I have 6 dogs.... the horn sets them off....
And also, if you think the question Is weird, and Don't have a clue as to a logical answer... move on to another thread.👍
In reality, it's for us old folks that aren't sure we pressed it to lock the doors. The second push confirms if memory cells are working in the brain ;)
Vector6
Juan Carlos Escobar
2023 Mav XLT high bread
(y)
Good deal, thanks for playing....
We now return you to your regularly scheduled forum.
Ballbearing
Winchester Virginia USA
2023 Ford Maverick
Again with such weird questions. I don't mean to pick on you, but why is this even a question? A double tap of the fob creates a horn tone and one does not. Solution is to just push it once, or use either interior or exterior lock pads when exiting the truck and no horn tone.
OR, just lock the doors with the Ford Connect phone app.
Vector6
Juan Carlos Escobar
I don't use that app, hell I don't even drive it...
Its hers, She drives it.... its so quiet when she comes home that when she locks it ..... ahhh crap....
Yeah we got it figured out. thanks
fossil
ernie
ohio
I must be the only one here that doesn't use electronics to lock up.
WJOHNM
New York,LI
Any way to disable the horm beeping when locking the doors from the fob?
You can lock the doors with one door open then close the door when ready, no horn, locked. Can anyone tell me why my doors lock with truck running with me out of the vehicle its happened 2x to me. Doors shouldn't lock with vehicle running, only when you put it in drive they lock.
Biagio
Biagio
Oakville
2023 Ford maverick
If you go into your menu on the cluster, select settings, then vehicle, locks, then select feedback there should be an option for audible. Hope that helps.
aam
Thank you!
Whitespys
Jose
New York
Ford Maverick Hybrid
Super late to the thread here. I had a 23 XLT Hybrid that was just totaled by insurance. It can be programmed from the infotainment system to not beep on a double tap. It did still double beep if I left something open like a door or hood. Super handy and I don't like loud noises. I have just taken possession of a 24 Lariat Hybrid and cannot find the setting.
Deleted member 35678
Guest
If you only press the button once it shouldn't honk.
Agreed but when you have the global window roll up setting it requires you to press once then hold on the second time. The windows go up but you get that annoying honk sound.
Guest
To all those wondering it can be turned off. You have to use forscan to do it but it can be done. I’m also on the side of just push the button once if you find the horn annoying as all doors lock on first push.
Are you just saying it’s in for scan or can you tell me which module and setting to change?
It's in the BCM settings. I believe you can also configure Global Windows to only require a single 2-sec long press, but I haven't tried it.
