Dirty pants getting out of Maverisk
Cowboy George
George
Bandera Texas
2025 Ford Maverick
Anybody got a solution to keeping your pants from getting dirty on the rocker panel at bottom of front doors? I live on dirt road and impossible to keep this always clean. Its a real trick to try to overstep the rocker panel while getting in or out f .
Cherokee
The biker code.
Wear black or denim. Black and denim show strength and hide dirt.
If you wear khaki shorts, or
Pink your on your own.
ScottyC
Central NY
2025 Ford Maverick AWD hybrid
Levitate or teleport.
Cancunbadlands
Cancun
Cancun
Because of the vehicle's body geometry and how the lower door seal fits over the rocker panel, the lower edge of the frame tends to collect road debris, which then transfers directly to your pant leg as you step over.
Instead of sliding out and letting your legs brush the rocker panel, consciously lift your foot up and completely over the door sill.
Grand Nat.
NYC/ L.I
Schwinn Stingray
Sawzall will cure that problem. Or cowboy boots. LOL I agree with you. I don't care for that leg lift I have to do when I step out of my Maverick. My Ranger is easier to step out of.
Ford Maverick Dirty pants getting out of Maverisk 240_F_460723239_phSwq390c4BnkdcWCOgYwus67rvxHURj
OleFordGuy
🤷‍♂️ keep a soft bristle brush or rag in the door pocket or in the floor beside the seat to wipe the dust off
Tunnelman
Stan
Emery MI
2025 Maverick hybrid XLT, 2014 F350 6.7, 2007 Ranger Super Cab, Sport
Yeah, Put mudflaps on. I live on a dirt road also, these roads were a like a mini mud bog, this spring, also had snow tires on, which really throw the mud. I put the longest and widest mudflaps on that I could find. It helps, cut it down quite a bit, probably got on my jeans twice.
Tim d
Alpena
Ram
I have this issue with every vehicle I've owned, not specific to the maverick.
rtphokie
Tony
Raleigh, NC
2025 Maverick XLT
This.
The Maverick is no different than any other vehicle. It looks better and lasts longer if you keep it clean. 99% of that is wiping it down with a rag. it takes seconds and makes a huge difference.
mkebikecop
ed
Middleburg, FL
2024 Volvo S-60 recharge, cloud white, 2025 Maverick Lariat, hybrid space white
Going to a car wash and if you get tire dressing for your tires or if you put it on yourself, it an oil base product that appears clear. However it spins off onto the fenders and running boards. This spray picks up road dirt and that may be what is getting on your slacks
Geo8866
Pennsylvania
2025 xlt
OP's one and only post was about his pants getting dirty when they touched dirt on a dirt road. I guess I chose one of the suggestions about and moved on.
themartymac
Marty
Victoria - Canada
2026 Ford Maverick XLT
