Deep sleep mode fix?
Welp, that didn't work for me. I had them run the 2 software updates and this morning...... the dreaded Deep Sleep mode warning. Ugh! Now they want to replace my battery. I'm sure with one of the shitty flooded Ford ones. Even though I told them I had replaced it with an AGM DieHard a year or two ago. I'm at the end of my warranty, and they know it, so they're probably just replacing the battery to buy time 'til the warranty runs out. F@ckin Ford better fix this sh!t!
Winter and colder temps where you are at?
So you are aware even reading thru this rather short limited thread (compared to others) - your battery was likely already ruined - so doing those 2 updates won't magically fix anything here & now.
You'd also be aware the warranty replacements almost all seem to be the AGM the 25MY came with, not the spec'd FLA.
Fil
TN
2023 Ford Maverick Lariat
This is the warmest winter in 5 years. Last week it was 72 degrees. And the problem has existed for three years.
Yes, I have been reading this forum for years and knew that it had ruined the crappy flooded original battery. So I replaced it with a Die Hard AGM battery that someone in this forum suggested and also said it fixed his issue with deep sleep. It didn't. I hadn't read anywhere where they said Ford was replacing the batteries with AGMs. But it won't fix the issue.
