Dash Cam can it be powered from mirror?
haze10
Rhode Island
2024 Maverick Lariat Hybrid
I have the 2024 Lariat Hybrid. Want to install a dashcam but looking to avoid any complicated wiring. I know there is electronics in the rearview mirror package for the onboard camera/lane keeping/ cruise control. Is there a way to connect into that power supply to power a dashcam.
ShadowBlack XL440
Robert
Northern Ohio
Are you looking for ways to void your warranty? Run separate power for accessories.
BradnChristine
Brad
Wyoming
Yup. Not for the faint of heart to wire, but there is a 12 pin connector to the assist camera. Get a plug, a new socket and 8- 22 ga wires and affix your 12 volt socket or a 5 volt buck converter to pins 4 (power) and pin 5 (ground). I have dashcams for both my Mavericks and my 2020 Transit connected this way with patch cords. The Mavericks also have the Kia mirrors wired from this socket. You should be able to find the part numbers here with a search.
Ford Maverick Dash Cam can it be powered from mirror? 1718380223299-nh
haze10
Rhode Island
Just to clarify... You are saying the purple wire (4) in 12VDC hot, and the black (5) is ground. Is that correct. Don't understand about needing a plug, new socket, and wire.... I would just use a crimp on tap connector.
Any recommendations for dashcam?
Any more info on the Kia mirror?
AF Blue
US
NA
Don't know the answer.
Don't have Lariat or Lux pack.
Many Youtube videos linked from this site.
I have installed a dashcam (search wolfbox).
Running the cables from top center console piece along the headliner/windshield
and down "A" pillar to the fuse box was the easy part.
Getting the rear cam installed was more "difficult" part.
(quotes because it's more annoying dealing with the rear plastics).
Hot Runr Guy
West Chicago, IL
Just a FYI, those are about 24 gauge wires.
HRG
Ford Maverick Dash Cam can it be powered from mirror? IMG_1072.1
grumpyunk
tom
georgia
I already have concerns about the battery charge level, so wonder if the tap is powered 24X7 or is it switched by the ignition.
I would like to add a camera that records when there is any sort of impact... but don't want a dead battery.
tom
BradnChristine
Brad
Wyoming
Note that this is the full plug. Some XLTs/XLs do not use all 8 wires. Yes, you can just tap it. THAT would be a warranty risk. A patch cord can be removed without showing damage to the circuit.
Ford Maverick Dash Cam can it be powered from mirror? 1718396067545-yy
BradnChristine
Brad
Wyoming
HRG
22 ga, per the Ford manual...at least in the assist camera. I think the same for the light module.
BradnChristine
Brad
Wyoming
Here are the three parts needed for a patch cord. Plug, socket and pins from Mouser Electronics. Less than $15, shipped. I used 16 pins for the 8 wires (about 4" long). Buy some extra if you try this. Wires I used are from Amazon: https://www.amazon.com/gp/product/B07TX6BX47/?th=1
Ford Maverick Dash Cam can it be powered from mirror? Molex pins
Ford Maverick Dash Cam can it be powered from mirror? Molex plug
Ford Maverick Dash Cam can it be powered from mirror? molex socket
Suzukiridr14
Frank
Sarasota Florida
I have a dash cam that plugs into the cigarette lighter like most dash cams do. I think the problem with hard wiring the camera is that the voltage from the plug in at the lighter is reduced to 5 volts before it goes to the dash cam. Check before you put direct 12 volts by cutting out the connector, I'm just guessing that might be a problem.
LSchicago
Lloyd
IL
Sounds like are looking to complicate your wiring.
