Coolant Levels 25 2.0L EB.
mav-bomberman
Virginia
2025 Maverick XL 2.0L EB
Hey all - I recently purchased a CPO 2025 2.0L EB and just getting accustomed to the vehicle. I am having some trouble identifying the actual level of coolant compared to the min and max lines. In one area it looks midpoint in another it looks right on the min line and curious where I should be gauging the level off of. Thanks!
searched the forum for a similar post but wasn't able to find one.
Ford Maverick Coolant Levels 25 2.0L EB. 0A125770-9383-40AE-8446-60156B1905F0_1_105_c
Brian_J
Akron, Ohio
'22 HPR Maverick AWD 4K LUX
personally i'd top it off to the full line then monitor it from a known starting point.
Chops
Lobo
Here is what the 25 Manual says. I would add “check your coolant on level ground”. It appears your reservoir is slightly tilted?
My 2025 EB is slightly above “min” when cold. I’m not expecting to have to add coolant for a long time on the sealed system….
Ford Maverick Coolant Levels 25 2.0L EB. IMG_0616
mav-bomberman
Virginia
Thanks for the advice! I am parked in front of my house which I guess I didn't realize does somewhat slope to the right so will check on more level ground. Good call out
22XLThybrid
Paul
York, Pa.
2022 Maverick XLT hybrid (order July 21)
I like to have it at Max with a hot engine. It gives you some extra coolant in the system if you should get a leak. If you're worried about coolant consumption, just mark the bottle at hot and see if it changes.
