NJBob
New Jersey
Certainly does. Should have thought of that.
KE4JLA
Josh
Hampstead, NC
2023 Ford Maverick
Does anyone know if the third brake light antenna mount has good ground? I am trying to get the ATAS antenna from Yaesu installed next and wondering if that location will be reasonably as good as a roof mount NMO for HF with the ATAS.
24Bret
Michael
So Plains, TX
2024 Maverick Lariat, 4K Tow, White
Can't answer that question . You could take the mount apart and run a 1/2 inch braid from the mount to a ground location under the backseat.
24Bret
Michael
So Plains, TX
KE4JLA - Did you find a control wire path under the little storage container? Plan to use that Bulletpoint mount, but would like to run the control cable "hidden."
Aherpa
Iowa
Edge, Maverick Lariat Hybrid
Now that you have had it installed for awhile, what kind of range are you getting with the setup for two way conversations?
Thanks
