Check Engine Light Fuel Tank Assembly
Benjam1n
Benjamin
Albuquerque
Ford Maverick Hybrid 2022
Hybrid 2022 Maverick Miles 40,000
The check engine light came on and I took to the local Ford dealership and this is their response
The fuel tank assembly needs to be replaced and you are out of bumper to bumper warranty by mileage. The full repairs would be $2725 after tax.
Is this a known issue and why would they need to replace the entire system?
KevCuRaoi
Kevin
Buffalo, NY
2025 Maverick Hybrid XLT AWD
What code does it have?
KevCuRaoi
Kevin
Buffalo, NY
The dealer didn't share any additional info with me.
If you want to share your VIN, I can see if there's anything I can see. I work at a Ford dealership, and might be able to see what they think is wrong that is causing them to want to replace the fuel tank.
Meeka
Jay
Castlegar B.C. Canada
2024 XLT 2.0 turbo
You’re not the ‘Bot’ are you?
Benjam1n
Benjam1n
Benjamin
Albuquerque
I sent you the VIN INFO 👍
Benjam1n
Benjam1n
Benjamin
Albuquerque
Got it, I'll send you the info that I can find about your issue!
O'Reily's printed out a paper and said it was a fuel sensor that had to do with the emissions. Said they don't carry part and to take to Ford because of it being a newer vehicle.
KevCuRaoi
Kevin
Buffalo, NY
That is probably the most common issue that that code relates to, but is not the only possibility
What is the manufactured month/year on the driver's door tag?
Broadly, New Mexico followes CARB regs so those emissions warranties apply. So I'd think it should be covered under the 3yr/50k mile short-term emission control defect warranty if not the 7yr/70k mile long term defect warranty.
Ford Maverick Check Engine Light Fuel Tank Assembly 1730932639126-4v
Ford Maverick Check Engine Light Fuel Tank Assembly 1730932737221-sj
If it was Job 2 then it'd be SULEV30 certified which has an even longer, more comprehensive emissions warranty.
Benjam1n
Benjam1n
Benjamin
Albuquerque
It's a 2022 but don't have the info handy why? What were you thinking?
