Check Engine Light Fuel Tank Assembly
flashfearless
Alan
2022 Ford Mav Lariat Hybrid,2014 Ford Edge Limited
Glad I bought txtended warranty.
Glad I opted for the 2.0 turbo!
Curious why you would think an odd not common issue with something in/with fuel tank would not happen on EB?
They don't state what issue exactly - but not exactly a bunch is uncommon between the 2 models, compared to all the other things being required on both.
I would not be shocked if it really does require a whole new fuel tank assembly on both models for exactly the same issue. (if that truly is the only solution to actual issue, which I'm skeptical of anyway).
TCPTX65
2023 Maverick XL Hybrid, 2023 Buick Enclave
Check the owner's manual. On page 530 it says this:
MANUFACTURER'S WARRANTY COVERAGE: (For 1990 and subsequent model passenger cars, light-duty trucks, and medium-duty vehicles.)
- For 3 years or 50,000 miles (whichever occurs first);
1) If your vehicle fails a Smog Check inspection, all necessary repairs and adjustments will be made by Ford Motor Company to ensure that your emission control system PERFORMANCE WARRANTY.
2) If any emission-related part on your vehicle is defective, the part will be repaired or replaced by Ford Motor Company. This is your short-term emission control system DEFECTS WARRANTY.
- For 7 years or 70,000 miles (whichever occurs first);
1) If an emission-related part listed in this warranty booklet specially noted with coverage for 7 years or 70,000 miles is defective, the part will be repaired or replaced by Ford Motor Company. This is your long-term emission control system DEFECTS WARRANTY
Ford Maverick Check Engine Light Fuel Tank Assembly 1731368809383-
Of course that assumes your problem is related to emmissions.
That's for California and other CARB states as mentioned earlier in thread. NM technically is, but doesn't go into effect for a few more years apparently.
XL Hybrid Cactus Gray
United States
2022 Ford Maverick Hybrid XL
I used to have the Check Engine Light come on every 1-2 weeks, seemingly random.
Frustrating and dealership was no help with diagnosis either.
Read some threads here about not topping off hybrid fuel tank.
Something about the pressurized/capless fuel system and that little bit of extra gas from the 2nd pump would throw a Check Engine Light.
I no longer top off the fuel at pumps (1st click and done) and have not had the Check Engine Light re-appear.
Has been over a year.
Correlation is not necessarily causation, but that worked for me.
2022 Hybrid XL with about 57,500 miles.
