Cheap DIY bed rack that works with tonneau cover
Blacksmith
Kir
Maverick hybrid
I've been looking for the cheap bed rack which will work with my Truxedo pro x15 for the last two years. And didn't find anything.
Truxedo cs is the most popular option here, but still 900 USD +.
The other racks doesn't work with the cover.
So I found this simple solution on the jeepgladiator forum and decided to adopt it for my Mav.
https://www.jeepgladiatorforum.com/...t-slot-rack-for-bak-revolver-x4s.59111/page-4
Bought 1.5" t slot beams, brackets, fasteners, can of loctite from mcmaster and pair of cheap cross beams from Amazon.
https://www.amazon.com/gp/aw/d/B09NZPDZZ1?psc=1&ref=ppx_pop_mob_b_asin_title
It took less than an hour to assemble it and install on my truck.
Here is the result.
It's sturdy and my kayak will definitely fit there.
I didn't feel any excessive noise on the highway and don't see any drop in fuel consumption. At least so far
Ford Maverick Cheap DIY bed rack that works with tonneau cover IMG_20231121_151548__01
Ford Maverick Cheap DIY bed rack that works with tonneau cover IMG_20231121_151601__01
Ford Maverick Cheap DIY bed rack that works with tonneau cover IMG_20231121_150718__01
Ford Maverick Cheap DIY bed rack that works with tonneau cover IMG_20231121_150737__01
PS: Sorry for the duplicated last photo. Looks like delete button doesnt work on this forum
Zomdos
Rob
Chicago
This is fantastic thank you for sharing!
How much space is in the back between the cover and the tailgate? Are you still mostly water tight?
TheSEARCH
ford
Here is the result.
Great setup. I used yakima clip on bars on roof BUT I would like to do at least one cross bar in the back so I can load from the rear rather than the side. In have a few questions I hope you don't mind
So I would start with rails 50 inch rails only , correct?
https://realtruck.com/p/elevate-rack-system/v/ford/maverick/2023/
. I want to load from the rear of truck kayaks like you.. 16' foot and 17' 2" kayaks. (Valley Avocet, Tiderace Pace Tour 17)
So I need TWO of these per cross bar BUT not sure on length. Yours looked like perfect length for proper height
to clear roof. , What length did you use?
https://www.tnutz.com/product/ex-1515-black/
So I would need Brackets 6 per cross bar
https://www.tnutz.com/product/cb-015-k-black/
Nuts that wont spin inside the slots? Is this what you used. Plus 5/16 bolts not sure what Length??
.Is that what you used below?
https://www.amazon.com/gp/product/B07TK14BW3/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1
Ford Maverick Cheap DIY bed rack that works with tonneau cover 1
Ford Maverick Cheap DIY bed rack that works with tonneau cover 2
Ford Maverick Cheap DIY bed rack that works with tonneau cover 3
Ford Maverick Cheap DIY bed rack that works with tonneau cover 4
Blacksmith
Blacksmith
Kir
Maverick hybrid
I used four hollow aluminum t-slot rails 2 feet long.
Then on the cross beams itself. They are actually flat on the bottom. So its just a direct contact between two flat surfaces :)
As for the gussets, I used 12 aluminum gussets 47065T798 from McMaster. 4 T-slot fasteners are included with each gusset. Thats what I used there.
Here is the link to traditional t-slot fastener
mcmaster.com/47065T905/
In general this setup is really simple.
I didnt modify any parts, just bolted everything together
TheSEARCH
ford
So you used Mcmaster.com for everything ?
The link you gave us for those washer but they are 1/4 inch. You used 1/4 inch? Seems small?
So these upright 1.5 inch hollow t-slot rails at 2 feet long each?
https://www.mcmaster.com/products/t...w/t-slotted-framing-component~rail/?s=t-slots
And these are the gussets
https://www.mcmaster.com/47065T798/
Now if I get the hollow Tslot bars and the gussets which come with washer and bolts? Plus mcmaster.com/47065T905/
Do I need anything else ?
Sorry for all the questions BUT this is all new to me making things like this .
Blacksmith
Blacksmith
Kir
Maverick hybrid
I included this link to t-slit fasteners just for reference. You don't need to buy it. As I said each gusset comes with 4 fasteners. So you need 2 feet rails, 12 gussets and 2 cross beams from Amazon. That's it.
Oh, by the way, don't forget to buy small bottle of loctite to fix all these fasteners in place :)
TheSEARCH
ford
Thank you very much for your help. My kayak loading will be faster and easier next summer for sure.
NatePabrant
Nate
24 Tremor
I'm not understanding how you have a water tight tonneau cover but also rails at the edge.
Blacksmith
Blacksmith
Kir
Maverick hybrid
It's definitely possible with the right cover. I'm using Truxedo pro X15 soft rolup cover on my orange truck and Rough Country hard tri fold on my blue one. Both trucks have rails.
Basically you have to install rails first and then rails which comes with the cover above it and clamp in place with 6 clamps. I'll try to post picture tomorrow. It's just dark and raining outside :)
NatePabrant
Nate
24 Tremor
I have the Ford hard tri-fold (I'm pretty sure it's rebranded but I can't remember what the other forums users said it was).
Do you know if it can have rails?
Blacksmith
Blacksmith
Kir
Maverick hybrid
I think I saw a good table somewhere on this forum with a list of covers which work with the t rails. I'll try to find it
Hammer
Easton PA
2009 VW GTI
Ford hard tri-fold is the rebranded BakFlip G2
