Can't pull out 4 switch panel in console to install auto start/stop jumper
Geppetto
Holly Springs GA
2024 Maverick Lariat
Ford Maverick Can't pull out 4 switch panel in console to install auto start/stop jumper console switches
Read several guides on how to install jumper cable that allows you to override auto start/stop but can't pull out switch panel. Picture shows two spatulas that I've inserted that our supposed to relieve clips to allow panel to come out. You can see some dings where I've tried to wedge out to no avail. What am I doing wrong? 2024 Mav Lariat.
dsr500sl
ds
oregon
24 maverick
If you get the '4D tech' bypass the console switches don't need to be removed because it plugs in under the dash - no removals needed. Easier Install
DrEvil
Stephen
24 awd turbo maverick
My buddy's four by four shop. They cut a plastic 7/11 sandwich container in the two strips , one by three inches. They slid them down both sides of the switch , left and right. Popped it out with a plastic prybar . Took two minutes.
dhaskit
Dann
2024 Maverick FX4 Lariat
Same problem here.
I bought the device that plugs into the 4 switch box but have not been able to remove the switches either to make the installation. Uuug.
I watched one guys video where he cut a plastic Coke bottle to slide down into the crack to release the retaining clips. I have not been able to accomplish it yet and I’m not willing to scar up my truck.
I did see where other folks are disassembling the center console, starting at the front and working back to get to it from underneath. I’m also not willing to do that either. As frustrating as it was initially, I just added 'Pushing the Button' to my start procedure before every flight.
Long story short:
It ain’t as easy as it looks like, is it?
brothernumpsy
Mansfield, Texas
2025 Ford Maverick XLT 2.0L Ecoboost
I was able to remove mine with two plastic trim tools. You need something thin, and you need something made of plastic so as to not scratch the vehicle trim. I think you have the tools in the right locations, but the tabs keeping the switch panel in place are too low for your tools to reach. I would suggest trying what others have mentioned and use discarded plastic packaging to fashion your own tools.
Misterwakko
Wrench
Connecticut
2022 Maverick FX4
Don't bother.i almost broke mine.
Remove center console.very easy. Lean to one side and install the device. I'll give more info when I get out of work. 😆
markinvictoria
2023 Maverick XLT
I had the same problem...was afraid I would break the switch. So took the whole console loose and removed the switch. The jumper that attached to the switch was about $15...the thing that plugged in under the dash was about $100. The best $15 I spent on the Maverick.
DrEvil
Stephen
I stood on the passenger side and watched him. Slide the plastic on each side of it. Work it down. Then a thin plastic prybar.pried it up a 1/4 inch and then pop the other side .no damage.
DrEvil
Stephen
It Was the stiff plastic from the lid of a seven eleven triangle sandwich box.
Medicman14
Kansas
23 Maverick XL 15 Fusion 93 Tempo 74 HD Sportster
I used 2 old credit cards, sliding them down on each side. You will feel the tabs release and the panel should pop up a bit. No prying was necessary in my instance.
austenite
Ottawa, Ontario
2022 Ford Maverick XLT FX4
I removed the driver's side center console kick plate, and reached back to disconnect the switch wiring harness. I was then able to press the side tabs and eject the switch assembly from below. You need skinny forearms to do this, and I did get a few scratches.
Attached are some pictures to see the design of the tabs. If you want to try the thin plastic method from above, make sure your plastic tab is no wider than 1cm or 3/8".
Ford Maverick Can't pull out 4 switch panel in console to install auto start/stop jumper 20260228_144130
Ford Maverick Can't pull out 4 switch panel in console to install auto start/stop jumper 20260228_144020
Ford Maverick Can't pull out 4 switch panel in console to install auto start/stop jumper 20260228_144058
Ford Maverick Can't pull out 4 switch panel in console to install auto start/stop jumper 20260228_144308
Cancunbadlands
Cancun
Cancun
You can use 2 credit cards, sliding them down on each side to get the tabs released
