Calibrated MPG display
crgator
Ron
Space Coast, Florida
2023 Maverick XLT
Went into Engineering Mode a couple of weeks ago, and calibrated the MPG display. I filled up yesterday, and, after months of calculated mpg being about 2.5 mpg, it came in at a difference of about 1 mpg. When I adjusted, I already had about 150 miles on the tank of gas, so I'll see how far off it is on my next fill-up. I'll decide then if I want to make any further adjustments. I've never had a vehicle that the calculated mileage comes within 1.5 to 2 miles of what the dash shows, and I guess it really doesn't matter a lot. It's just that when it's reading 42 mpg, I like to know that's what it is. I might add, it was a pretty easy job.
K5Blazer
Colorado
2023 Maverick XLT
Good info.
I manually calculated my mpg for about the first 15 fill ups and compared it to the mpg display number.
My computer estimate was within 1-2 mpg, sometimes higher, sometimes lower, to my manual figures. Often is was almost dead on.
The mpg display was so close most of the time I quit ciphering manually.
I have had a couple cars that had pretty accurate readings. It surprises me when I read how many people don’t seem to have particularly dependable dash readout figures.
realshelby
Houston
1969 GT 500, 1965 Mustang GT,
I am "experimenting" with adjusting the calibration on my Hybrid now. First fill up after calibration I was actually getting better real world mileage than display showed. Made an adjustment and will see what the second tank does. Not after perfection. But would like to see if I can get it under 1 mpg on most fill ups when comparing. Then I won't have to do the manual check just to satisfy my curiosity every time...
GPSMan
Many
A few of us find setting the offset to 950/1000 is an accurate setting.
5% adjustment down.
crgator
crgator
Ron
2023 Maverick XLT
5% adjustment down.
I don't recall where I set mine, but I think it was 965, and I figured I'd have to go down a bit more. I'll see after this tank. I'll keep the 950 in mind.
MaveRichard
Rich
MI
2023 Ford Maverick XLT Hybrid
950 is the number, at least for my truck and a few others.
…unless you are using remote start in a manner that is causing the ICE to run (cold weather, low HVB charge). Because the trip computer is not “awake” during a remote start cycle, it does not accurately factor this fuel used into MPG calculations. I can watch the accuracy go down even from 1 or 2 remote start sessions in a full tank.
I have around 5 tankfuls within .1 mpg accuracy since adjusting this
Terry52
Smyrna DE
2022 Maverick XLT
When you say you went to Engineering Mode, what do you mean?
MaveRichard
Rich
MI
Start with the truck off and door closed. Hold down “OK” on the steering wheel for ~10 seconds while you turn key to “RUN” without actually starting the truck. Let off of the OK button when you see “ET” in green on the dash. This stands for “Engineering Test” mode.
You can scroll through options until you see something like “AFE Bias”. This is the value that we are changing.
If you have a Lariat it is similar - you just press the start button without your foot on the brake.
Hopefully I am explaining this in a way that makes sense…
Terry52
Smyrna DE
2022 Maverick XLT
Thanks very much for your explanation, very clear. I will need to do this because I generally read about 2 mpg more than the actual mileage. That is based filling up and counting against total mileage. Appreciate your comments
crgator
crgator
Ron
2023 Maverick XLT
Actually, MaveRichard beat me to the explanation, so you owe him the thanks. Try setting it somewhere around 950. I've read that number before. I set mine to 965 (I think) and will revisit after this tank of gas if needed.
Timothyd
Good info.
Same for me.
TheSEARCH
ford
I am only on third tank but its been pretty close to right for me. Maybe its because I have a big kayak on the roof its more accurate?
Ford Maverick Calibrated MPG display e
Eagle11
Valley of the Sun
I just changed mine to 950, I saw a lot of interesting things in ET mode, is there a thread that explains what is in there?
GPSMan
Many
Except for the fuel economy calculation, the rest is informational only. Nothing else is user "adjustable".
Bill Quattlebaum
Blackville, SC
2024 Maverick XL, Ecoboost 2.0
My mpg has been over by about two mpg for the first 3,000 miles. When I checked it today it was off by 3mpg. I need to adjust this, but can't get to the right screen. I can get to the eng. test screen, but not to the adjustment screen. Not sure what I am doing wrong. Thanks for any help. Seems the arrow keys aren't working for me.
