Budget friendly front speakers?
Ferroplasm
M
Subaru Outback Onyx XT
I'm aware of the powerboost direct replacements, but can't justify spending ~$120 each when I primarily listen to podcasts and NPR. However, the XLT speakers are just terrible and I need something a little better.
Recommendations for budget friendly options?
Chris_G
NOVA
C-6 Corvette
JBL CLUB 6520 6.5"
Chris_G
NOVA
C-6 Corvette
Brilliant, thanks! I don't have a great deal of experience with car audio. They a reasonably straightforward install?
I haven't installed them yet. The speakers were mentioned here on the forum with positive results.
AnthonyMav
Anthony
New Jersey
Maverick XL Hybrid
JBL CLUB 6520 6.5"
Are they plug and play with the existing harness or do you need to splice and rewire? And so they fit the door card without trimming?
Chris_G
NOVA
C-6 Corvette
Order the connectors, no need to cut wires. Connectors are mentioned here on the forum.
The Hater
Josh
2005 GMC Yukon
Just wanting to add that while the power boost speaker upgrade is more than what you are budgeting. It does replace 4 of the six speakers in the truck for that price. After doing the swap my self I noticed that the tweeter replacement up front has really helped out with hearing the lyrics. It cleans up the audio a lot and makes it much more enjoyable to hear, I'm sure it would help out with the podcasts as well. The door speakers offer slightly better bass, but I'm still going to be looking to do a full speaker swap by replacing the back two next, and possibly adding an 8" sub later.
Good luck with what ever you wind up swapping in there, the XLT speakers are definitly the weakest link on this pick up.
Ferroplasm
Ferroplasm
M
You know, I haven't even really looked, but does the XLT have tweeters? I thought it was just the front door and rear b-pillar speakers.
The Hater
Josh
2005 GMC Yukon
It does have 2, 1" tweeters up front. The power B comes with them in the package and like the door speakers they are plug and play. Full disclosure, they are a pain to get to. Getting them uncovered was the hardest part of the swap. There is a YouTube channel called blakescars I believe that has a video showing them. There's probably several threads on here as well if you go digging for a bit.
Slightly less ideal but you could also get the Powerbass coaxial 6.5 speakers for $20 cheaper and just replace the doors.
If you get other speakers expect to account for another $20-25 for the speaker mount rings and adapter harness (unless buying through Crutchfield which includes them, I believe).
Montana
JP4AZ
Phoenix
Infinity REF 6532IX 6-1/2" Reference Series 2-Way Car Audio Coaxial Speakers (also a very good replacement speaker) will require mounting and wire adapter(s).
https://www.ebay.com/itm/133763660086?epid=11017472703&hash=item1f24ef7936:g:2hcAAOSwEVNgotWG&amdata=enc:AQAIAAAA8BOLXETortakYd6a/BNlWW/yFdyaIyMl2R69Q0kcFf4Tk50lTqVRsQXE6b0BktMTers8FXSgApVKDOjVXbdYPl6f8fTzxoqgzyQMydkvlVcdv0Y62X3X7f78ZKqvzDLtaZriLyvz8ra9EjIwM4WotXOTH0+urYUqfWvYK/ww7noOMf0UXVz0gtFklQC8d57s3tZOYCLuatkOhcX6rGwSZwVSnxxr9jSuM1YLARiSZq442ko/xbN/jue9L+wqX31OPcLOpAEHTJCKXeUIzScIwYsVUoNgodEmX4riwu+W+oJKFx17RPdjqYTBatmSGnpGig==|tkp:Bk9SR6yHpL37Yg
_________________________________________________________________
** These will bolt and plug right in (no wiring) ** probably the easiest option available:
PowerBass OE652-FD - 6.5" Ford OEM Replacement Coaxial Speakers - Pair
https://www.amazon.com/dp/B07DWF9DX...PC6S5WYO&psc=1&ref_=list_c_wl_lv_ov_lig_dp_it
