installed new front speakers
Decayed
yes
a car
Didn't take pix. But I didn't die. Or break anything. They sound a bit better and don't distort as much at higher volumes as the stock ones. Not super high end but my hearing isn't good enough anymore for it to matter.
Getting the door panel off could have been worse. Putting it back was much worse than taking it off. Had a hard time getting everything lined up then I figured out that the panel had to overlap a slotted thing that runs next to the window slot. It doesn't go in the slot it goes over it.
Everything came from amazon. Amazon links don't seem to render correctly on this site so just copy paste the description on amazon since that's where I copied it from.
PIONEER TS-A1670F 3-Way 320 Watt A-Series Coaxial Car Speakers
I used these connectors and the mounting rings that came with the speakers:
Metra Electronics 72-5602 4-Way Speaker Harness Connector for Ford & Mazda Vehicles, Multi Color
I just ran the wires between the ring and the door and didn't bother cutting a notch in the rings. Lazy but effective.
You will need a 7mm and 8mm socket along with a spludger and a phillips screwdriver to mount the speaker on the ring. I found that a small thin knife blade (small one on a swiss army knife) worked best to pop the window control switch panel off. Wiggle it under the end facing the back of the truck. After you remove all 5 screws use the spludger under the bottom edge - there is a little gap that is apparently there for that purpose. Then just get your fingers under and work them around popping out the clips. Be careful with the little triangular piece of trim above the door panel in front. It just pops off but one clip is different than the rest and it has a rubber fitting that can pull out. Almost broke that one.
Clock Doc
Mass
Ford Maverick 2.0 ecoboost, Ford Crown Victoria
Nice to know it's not diicult to do a swap. Guesstamet of how long the job took?
Decayed
Decayed
yes
a car
About 2 1/2 hours I guess. I was taking my time so I didn't break or lose anything. The first one took FAR longer than the second one of course- you have to teach yourself how to do it the first time.
Figuring out how to put the panel back on took the most time.
I actually did it wrong on the first one and had to completely disassemble it again because I didn't seat the top correctly. The first thing you do is you absolutely have to hook the top edge of the panel completely over the slotted thing next to the window THEN start lining up the screw holes and clips.
If I had to do it again I could knock both out in an hour or so.
One other tip - once the panel is free and you disconnect the wires for the window switches, etc., GENTLY let it hang by the cables for the door handle and lock. Just let it drop down and it will hang out of the way. Don't bother trying to disconnect them.
Clock Doc
Mass
Thanks! If it took you 2 1/2 hours I'm sure I could screw it up for at least 3 1/2. lol
Thanks for the tips they will surely save me some frustration!
Decayed
Decayed
yes
a car
Some guy named blakescars2 posted a youtube video on how to do it. His camera work doesn't show the details I talked about but it's a good overview. Just search ford maverick door speaker replacement.
