Broken taillight lens
crheyne
northern California
2022 1st Edition Lariat, 2024 XLT both hybrids
Has anyone had to replace a taillight lens on their Maverick? Someone backed into me and broke the passenger side lens. What do I have to do to gain access to it? Thanks..
ShadowBlack XL440
Robert
Northern Ohio
Easy to access, 2 screws inside the tailgate opening, then pull back and out at about a 45 degree angle. It will be more difficult getting it to pop out the first time but then easier after that.
Cancunbadlands
Cancun
Cancun
Whole housing has to be replaced buddy
Since it's needed to change bulbs - it's in the manual.
REMOVING A REAR LAMP ASSEMBLY
  1. Make sure the headlamps are off.
  1. Open the tailgate to access the rear lamp assemblies.
Ford Maverick Broken taillight lens Photo Feb 04 2026, 1 42 49 PM (1) (1)
  1. Remove the two bolts from the tail lamp assembly. Then, carefully pull the lamp assembly from the tailgate pillar by releasing the two retaining tabs.
  1. Disconnect the electrical connector from the bulb.
  1. To install, reverse the removal procedure.
Lookn4bikes
Boise
They come in 3 different levels. Make sure to match up the OEM number on the back. A call to the dealer with your VIN will also tell you which one. I worked in auto salvage for years and sold aftermarket lamps. They are usually good replacements, but I ponied up for an OEM when I broke mine.
Joaquin F
Joaquin
LA
2022 Mav Hybrid XL
It is the easiest thing to replace on the entire truck! lol
Lookn4bikes
Boise
There is a pair of lights for sale in the classified section.
