Bluetooth not playing audio
Honda CR-V
Has anyone had this issue and how to fix? Apple CarPlay works fine but Bluetooth is not playing music. However, it connects and can do phone calls over Bluetooth.
While connected, it acts like no audio device is connected
Ford Maverick Bluetooth not playing audio AB6BAD17-CB4A-4922-97F7-8FCA8B3E8810
Steve2u
Ranburne alabama
Ford maverick xlt
Try on your Bluetooth see if you have list for ford maverick deted it rescan it see if they will help
TimmH
Southwest Florida
2018 Jeep Wrangler
THe Apple carplay is by USB cable isn't it, so that would be no indication of Bluetooth connected or not.
Ensure the bluetooth device(phone) is paired to the head unit.
Honda CR-V
Connected by Bluetooth audio doesn’t work
connected by usb audio works
KevCuRaoi
Kevin
Buffalo, NY
2025 Maverick Hybrid XLT AWD
You can't play bluetooth music while you are connected to apple carplay/android auto.
Does the bluetooth audio work if you don't have it plugged in and connected to apple carplay?
I'm not familiar with iOS but it does have separate permissions for what features Bluetooth devices/connections can utilize? On Android you can specifically allow just phone calls and/or media playback. I'd check both are enabled.
TimmH
Southwest Florida
2018 Jeep Wrangler
I got that, but the message says no device is connected, so I was questioning whether or not you paired the device, VIA bluetooth, to the head unit , and as Darnon said, it may be a permission issue.
Ford Motor Company
Official Ford Account
Dearborn, mi
Hey there! I can look into your Maverick’s Bluetooth concerns on my end if you’d like. Will you send us a private message with your VIN and dealership info?
Honda CR-V
Yes, it is paired. It was working fine then just stopped. I tried resetting connection. Restarting phone and truck. Nothing is working yet
Honda CR-V
Update: i started my truck up after work and now it is working for some reason
Mavrookie 68
syracuse
2023 Maverick XLT Hybrid
I just got the same problem.
Rader002
Owen
Erie, PA
I'm having the same problem. I can go days without the issue and then all of a sudden it won't play music via Bluetooth. Normally if I walk away for a while, the next time I get in it's fine. This time not so lucky. I have restarted my truck, phone, unpaired them with and without the truck running, restarted my phone and nothing.
