Radio-Bluetooth issues
JB4TRUCKS
JB
2024 Maverick XLT
I have had my 24 XLT to the dealer several times. Intermittent issues where blue tooth is under able to connect with Samsung S25. Radio freezes at time forcing a manual reboot of the screen.
Curious if others are having similar issues
lm126027
Larry
Central MA
2024 EB
Next time try just shutting down bluetooth on your phone, wait a minute till the car recognized it and then reconnect bluetooth. Just yesterday the car connected to the phone and (I guess) was looking for Waze (that I had used the day before, thru android auto) and I had no radio or any way of connection the radio. Dropped bluetooth and reconnected it solved the problem. Strange thing is that it had worked normally when I ran an errand earlier in the day. Just something else to try that should be a little easier than what you did. No harm in trying....
nbmav
Kevin
North Bend, WA
2026 Lariat
I'm not seeing the freezing radio but I've been having connectivity problems but only when I'm near where I work. When I get about 1/4-1/2 mile away the carplay keeps resetting, going away, coming back for a few seconds then going away again.
I work near a rail yard and a pair of stadiums all jammed together and I'm guessing one of them is throwing out some significant RF interference or something causing the radio to wig out. I just recently tried connecting my iPhone via a cable rather than using the wireless connection and it seemed to work the first day but the next two it was up to its old tricks again.
Mean Green BP
Bruce
Covington, LA
2025 Lariat Eruption Green, 4K Tow, OEM Bed Extender & Light kit.
Everytime my phone alarms, like from my Diabetes Dexcom Ap when my blood sugar may be a little high from lunch etc, it throws the radio off of my FM channel and goes to the Pandora feed from my phone. Haven't figured that out as I gotta keep the Blue tooth on?
Cancunbadlands
Cancun
Cancun
It's time for an APIM replacement under warranty.
BRAT
Cliff
25 maverick xl
Im having issues where android auto works fine but blue tooth disconnects and you can't answer or make calls. Any ideas
Ecorydr
2026 Maverick Lariat AWD
Have noticed... wife and I own both a '26 Maverick and a '23 Superduty. If both are being driven within 30 yards of each our paired phones (with both vehicles) will try to connect to both and causes Fords SYNC system to get confused between the two when trying to call each other. Found this while driving back from the stealership after picking up the new MAV. 🤔
