Bed Plug
BeardedK
Kevin
22 Maverick XLT
What are the odds that the 120v outlet in the bed will be available to add on after purchase? I’d like to add it, but I’m not shelling out for the luxury package.
Lappo424
NJ
Accord - Looking to switch to Maverick XL
What are the odds that the rear 120v outlet will be available to add on after purchase? I’d like to add it, but I’m not shellin
Probably cheaper to do now... It's the only thing I got on my xl and I'll probably never use it
BeardedK
BeardedK
Kevin
22 Maverick XLT
Looks like some of my post got cut, I edited to add back in. I also said rear when I should’ve said bed.
sjJohnny
El Paso, TX
Maverick Lariat, Bronco Black Diamond
Add it as an interior option for $150 and you could at least use an extension cord for outside needs. Might also make it easier to add it to the bed later... as an add on.
edit: I see HRG had the same idea.
bentley72
Andrew
Columbus, Ohio
2026 Ford Maverick Tremor
Could wire in a power inverter with the 12 volt leads and hide it in the cubby box
BeardedK
BeardedK
Kevin
22 Maverick XLT
That’s what I was leaning towards, but I can see the benefit of having it already in the bed, especially during mosquito season. I’m not going to pop for the lux package though.
Thanks all!
BeardedK
BeardedK
Kevin
22 Maverick XLT
I completely forgot about the 12v power leads in the back. That’s my duh moment for the day. Good idea!
Hot Runr Guy
West Chicago, IL
I'm curious what they are fusing those circuits at. I've read one article that said 20 amps, but the Ford video seemed to show lighter-gauge wires than would normally be used at that level.
HRG
BeardedK
BeardedK
Kevin
22 Maverick XLT
guess we’ll find out in the Fall. I honestly feel like it should just be a plug and play module though. Time will tell though.
CACTI_HYBRID
Rick
Meridian, ID
2022 Ford Maverick XL Hybrid
Bet with some creativity you could add your own DC->AC inverter.
charlie
Charlie
Oregon
2002 F150
HRG
110v at 400 watts is about 3 amps. Might power a battery charger or laptop, certainly not enough for any sort of power tool.
Ford Maverick Bed Plug 1624377218722
Jukebox Nero
Carl
Draper, UT
2021 Ford Maverick Lariat Alto Blue FX4 4k 2.0 EB
That is, however, enough to power an M12 or M18 battery charger. I'll likely use it mostly for lighting, though many Light Trees push 1kW or more. Sadly, my table or miter saws would probably blow it up. But as you may have been leading, the design of this is not necessarily as a HEAVY work truck.
CSmith
CJ
Southern Indiana
2022 Maverick XLT FX4, 2020 F150 XLT FX4
My Maverick will be my temporary generator for my refrigerator if my power ever goes out in the house for more than a couple of hours. Keeps the groceries from spoiling!
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
Don't count on it, the amperage from the plug on the Maverick wouldn't be enough. It's not enough enough to charge high end batteries for cordless tools, let alone a fridge.
