Bed cubby install? (updated)
Scupking
2025 Ford Maverick XLT Hybrid
I just got a second bed cubby for my xlt. The install should be strait forward. My only issue is when the spray in liner was installed they sprayed over the tie downs... How can I take out the tie down without ruining the spray in liner?
Ford Maverick Bed cubby install? (updated) PXL_20220928_164447668_2
Update....
Cubby installed!! Used a razor and cut around the bolts on the tie down. The spray in popped off the top of them. I then cut around the tie down and was able to unscrew and pull it off without causing much damage to the spray in! You can tell they didn't remove the original blank cover when they in stalled the spray in.
Ford Maverick Bed cubby install? (updated) PXL_20220929_183802066
Ford Maverick Bed cubby install? (updated) PXL_20220929_183707206
Captain
Union County, NJ
63 Nova Convertible /
You can’t but, always a but…. You can buy a can of Spray in bed liner, or a can of roll on bed liner to make it look good again.
Scupking
Scupking
So no way just to cut around it with a razor? I don't care about the spray in on the tie down itself.
Cromwell
Oliver
Nova Scotia, Canada
2023 Maverick XL
A couple of Google results suggest a good utility knife.
Ford Maverick Bed cubby install? (updated) 0BE8FC1F-BE48-417D-B693-8719E92439C9
respi133
TX
Maverick Maverick
yeah I mean you could just undo the bolts and pull it out? or, like you've already suggested yourself, cutting close around the tiedown, being sure that when you reinstall it, you place it in the same place
respi133
TX
Maverick Maverick
What I will say is the installers for your spray-in should have removed all of the bed hardware prior to spraying, moot point now but it's not going to be difficult for you to remove the tiedowns and, if you do that messily, respray with a rattle can of bedliner
Allen King Jr
Allen
Springfield Missouri
2019 Grand Caravan GT, 2006 Mercury Mariner
Take an impact socket and use high torque to remove bolts, then replace with new bolts, if you do go this route, use a slight amount of anti-seize to seal the connection to negate water intrusion.
bentley72
Andrew
Columbus, Ohio
2026 Ford Maverick Tremor
Can you get an open ended wrench on the cubby bolt?
Scupking
Scupking
Yeah I should be able to remove the cubby bolts and cover without a problem. It's that I have seen videos saying you need to remove the tie down to install the cubby.
bentley72
Andrew
Columbus, Ohio
Now that I think about it, you’re right. I couldn’t get the cubby in without removing it 😕
respi133
TX
Maverick Maverick
yeah there's quite a few writeups on the bed cubby install, that tiedown has to come out.
make sure not to overtighten the cubby bolts, the thin plastic splits under pressure easily
Phileaux
Frank
New Orleans, La
2010 Ford Edge SEL fwd
In theory yes but they would have to use sacrificial bolts to protect threaded holes THEN reinstall hardware. They should have asked, probably more $.
Scupking
Scupking
The dealer is the one that did the liner. They didn't ask. Other than that they did a good job. My cousin that has a 2022 f-150 said my liner is much better than his factory liner.
Mymaverick2021
Steveo
Hilo Hi
And by doing it that way you have a better chance of not ripping the bed liner triggering a trip to the shop that did the liner(hope it's not factory)
TheWizziard
Texas-RGV
2023 Maverick XLT Oxford White
I am still waiting for my Maverick. Is the factory spray in liner over the anchors and cubby cover?
