BAP/Lariat tail lights
Rick T
Rick
Southern MN
93 Mustang Cobra,02 TBird,18 EcoSport,23 Maverick
Does the BAP have the LED lighting like the Lariat tail lights? Also, can either replace the XLT tail lights withoit any modifications or does there need to have a wiring kit. Thanks
Sticks
Shawn
St. Louis
The wiring for the LED signature should be present, but it won't be turned on in the BCM programming. Other members have turned it on in Forscan and posted it on the forum.
If you don't want to reprogram it, you could cut the wire going into Pin 5 at the tail light connector and splice it into Pin 2, such that Pin 2 feeds power to both wires on the tail light. It should be very straightforward when you see the wire routing on the LED signature tail light. No need to waste money on an adapter harness.
Ford Maverick BAP/Lariat tail lights 1717421001639-vf
