AWD Powertrain Engagement Sound or Something Else?
ImGoose
Houston, TX
Kia SUV
When I power down my AWD w/ 4K and FX4, I hear a metal rotational shutter sound. Hard to pinpoint the location, but seems to be in the rear of the truck.
Listen here at the end of the short clip:
https://imgur.io/a/QuY0mJT
I'm also realizing that when I'm braking and coming into lower speeds (<15mph), I can faintly hear the sound. Hard to match up, but think it goes in line with when the truck re-engages AWD.
What is that noise? If it's common, others with the same powertrain and AWD must be hearing it when turning off their Maverick. If it's not common, I need to get it checked out.
I can confirm it's not the active shutters on the front of the hood.
Shakesbear
J. R.
Sounds like something from my old "Battle Chess" video game ;) I have the same set up, and have never heard that.
Grand Nat.
NYC/ L.I
Schwinn Stingray
One of the sounds seems like the E brake applying. If your in all wheel drive when you shut the vehicle off then you might be hearing the RDU disengaging and reverting back to normal mode. Not sure. :unsure:
fossil
ernie
ohio
powering off at zero speed activates the parking brake.
RDU/PTU shouldn't be engaged during normal driving. whether it engages at shutdown isn't known, maybe.
<15mph deceleration sound? the only thing I know that's happening at that point is maybe a transmission down shift. should be silent but probably felt.
Mav2112
North America
2022 Ford Maverick Lariat FX4
Mine makes the same sound at shutdown; I just thought it was normal, quirky character of the truck. It’s done it since delivery over a year ago
bgn
WA
Have the same. Dunno what it is.
billbillw
Metro Atlanta
'23 Maverick Lariat FX4
I've never heard that sound on mine.
Do you have auto-hold engaged?
Mav2112
North America
commadorebob
I haven't heard it but I took delivery a month ago and my a/c is usually still blasting when I turn it off.
Mav2112
North America
Whatever the sound is, it makes it again upon restart, even when not being moved or having had the chance to use the awd. Cold starts of mavericks on YouTube appear to make the same sound; I’m inclined to think it’s just a characteristic of the truck
Ford Motor Company
Official Ford Account
Dearborn, mi
Hey there. I can look into your Maverick’s noise concerns on my end if you’d like. Will you send us a private message with your VIN and dealership info?
Halo9x
Hal
Abilene, TX
Maverick XLT 2023
One of the sounds seems like the E brake applying. If your in all wheel drive when you shut the vehicle off then you might be hearing the RDU disengaging and reverting back to normal mode. :unsure:
I hear the whine but not the link. Hmmm, I’ll try listening with the window down and see if mine does it. So far I don’t think mine makes that link sound.
Halo9x
Hal
Abilene, TX
Maverick XLT 2023
I hear the whine but have not heard the klunk sound at the end. I’ll try listening with the window down. I’m under the impression that AWD is always engaged. It’s not the same as 4WD that is engaged under certain conditions. I’ve had a 4WD before and you don’t drive with it all the time. AWD is constantly engaged. There is a difference.
Shakesbear
J. R.
