- First Name
- kevin
- Oct 2, 2025
- BATH CO ,VA
- 2022 XL maverick
- Engine
- 2.0L EcoBoost
yes also in the 70s they had to start rating gross HP( everything on the engine) the engines were still "torquey" but the lower compression and EGR took a hit on the HP numbers( they were so worried about nox( the former bugaboo on modern diesels,high combustion temps equal more efficiency,alas more nox as well.( the old diesel makers used to brag about"burning air" in the high combustion temp diesel engine,the manus seen a way to lower nox emissions without unduly crippling engine output( I give you "urea" injection in an exhaust reactor,much the same principle as the much maligned catalytic converter which arguably was a very good solution to gasoline emissions,make no mistake the demise of "tetra"lead had many benefits for engine and exhaust system longevity,so its not all bad,we have known how to make ethanol from corn a long time(moonshine) just scaling up was the issue.The 70's the automakers had more than enough going on. With the new emissions regulations, engine performance (power, economy, and drivability) all took a hit at the big three. They were also dealing with the pressure from loss of market share to Japanese manufacturers. They did not need another thing on their plate.
The US did not have much ethanol production capacity in the 70's. It takes a couple years to build an ethanol facility. Corn is the best commonly grown commodity for ethanol production in the US and we've never had a shortage of it. Brazil has the advantage of using sugar cane for their domestic alcohol production.
