- Jul 21, 2021
- Atlanta GA, USA (ATL)
- Fusion Hybrid, Mav XL Hybrid
- Engine
- 2.5L Hybrid
OK, lets compare, the Hybrid has all the following the EB does not have:More complex? How many moving parts to an 8 speed tranny? How about the accessory belts?
- Five electronic control modules the EB does not have https://www.mavericktruckclub.com/f...im-levels-and-options-found-by-forscan.11122/
- Two 3-phase high performance electric motors
- Two 3-phase high voltage motor drive electronics
- 400 VDC battery
- 400 VDC BMS (battery management system)
- 400 VDC to 12 VDC power converter
- Completely separate electronics/battery water cooling/heating system with multiple heat exchangers and circulation pump
- 400 VDC wiring harness
- 400 VDC contactor to safely disconnect high voltage on shutdown
- Electric motor driven A/C compressor since the engine may not be running
- Electric vacuum pump for brakes since it can't count on engine vacuum.
- Passenger compartment electric resistance heaters.
