Anyone replaced OEM back up light bulbs with extra bright LED bulbs?
BlueMav43
Roger
NE FLA
2023 Ridgeline RTLE, 2018 Tahoe LS
I did, no issues & rear visibility @ nite greatly improved.
Be sure the rear light assembly is completely seated before you tighten.
Dad
I replaced the front turn signal lamps with LasFit's and man are they bright. I feel a bit guilty for oncoming folks and I hope it's not too annoying, but I want to be seen.
I also replaced the bed lights over the rear window with LEDs and installed a 3x flashing brake light that's positioned in the middle of the bed lights.
Installed LasFit LEDs rear brake & turn lamps, but the recall rendered them useless. Re-installed OEM halogens and they are bright enough. Returned the LEDs to LasFit for full credit . . . very generous of them to honor their product despite no fault of their own.
I like the oversize rear light assembly on the Maverick. I've noticed some of the other newer vehicles on the road have much smaller lights. Style over function, if you ask me and not something I'd feel comfortable with in foggy or inclement weather.
By the way, per LasFit, the T3s do not work on the Lariat build.
MrTsTackleBox
Matt Tyrrell
Virginia
2022 Ford Maverick XLT AWD FX4 Hot Pepper Red
I replaced backup bulbs with ALLA Bulbs purchased on Amazon. Have had installed for 2 years and work well
Do you know if these work with the recall update and don’t hyperflash? Currently trying to find alternatives to my lasfit brake bulbs since they don’t sell the T3 anymore
MrTsTackleBox
Matt Tyrrell
Virginia
Tech Tye
Ken
Kentucky
2023 Maverick
I had these Alla super bright lamps until I put some feniex quad cannons in as I needed strobes.make sure to point the diodes left/right
Ford Maverick Anyone replaced OEM back up light bulbs with extra bright LED bulbs? IMG_2579
Hammer
Easton PA
2009 VW GTI
I only replaced back-up lights and so they are not subject to hyper-flash
mielelaw
23 Mav Tremor, 06 Vette, 11 F250, 07 Shelby, 79 TA
I had the original Lasfits and they hyper flashed but functioned and worked properly. When I heard about the new T3's I wrote to Lasfit and they sent me a free set. Put them in and they worked. Once I had the latest recall done (about 2 weeks ago), they would hyper flash for 2 or 3 blinks and they operated as normal, or so I thought. I had several cars pull up to me and tell me only my third light brake was working. I checked it out and they were correct. However, if I put on my turn signal for two or three blinks, the brake lights work just not sure for how long. This is not a good solution. I am going to try the original Lasfits (if I can find them) and see if they work other than the hyper flash which I can live with. Otherwise I will put in the original halogens just for the brake lights.
Lasfit confirmed that right now they do not have a light that will work but said they will let me know when and give me a discount code since it is over a year since I bought the original set and not entitled to a refund.
Swede.
Magnus
Gritcity, PNW
-24 XLT, FX4, 4K, 'Terrain'
I haven't gotten either actually. A bit spendy and the OEM's work good in conjunction with the camera.
Did you get the CR or the CR1? Are you still loving it?
