Anyone find a source for factory steel wheels?
GreatWhiteNorth
GreatWhiteNorth
Daryl
Winnipeg
2022 XLT
Deleted member 6544
Guest
tom_tucker
mid atlantic (VA)
2023 Maverick XLT (FWD)
Dunno about "way more sunk in", but they do sit about an inch or so further inboard than the stock aluminium wheel/tire combo. This is with Michelin X-Ice Latitude tires on Escape compatible aftermarket cheap steel wheels.
Sick. That's exactly with I have on my 06 Sub. For. XT. Michelin X-Ice on TireRack black steel (16 in). Hope to put these on the Maverick Hybrid for Winter 2023. Was thinking go all the way to Bridgestone Blizzacks. I've had good luck with front wheel drive and Blizzacks in deep snow.
Jakb
Jak
Minneapolis, mn
23 XLT Hybrid
Did you have to get new TPMS sensors or are you tolerating the light being on?
Does the Mav have the ability to store two sets of tires?
GreatWhiteNorth
GreatWhiteNorth
Daryl
Winnipeg
2022 XLT
I was reading and watching some snow tire reviews. The Michelin X-ice seem to be optimized for control in icy conditions rather than deep snow. At least that's what this comparison testing seems to indicate. The Blizzaks were better in the snow:
https://alltyretests.com/michelin-latitude-x-ice-xi2-test-review/
I'm with you on the FWD thing, traction can be quite good with proper snow tires.
GreatWhiteNorth
GreatWhiteNorth
Daryl
Winnipeg
2022 XLT
No TPMS on the steelies. I keep getting alerts on the FordPass Connect app on my phone! Can't remember if I'm getting a caution or warning on the dash.
Jakb
Jak
Minneapolis, mn
23 XLT Hybrid
tom_tucker
mid atlantic (VA)
Thanks for the link! I'm in the West Virginia mountains above 3000ft elevation. It's either raining, snowing heavily or slush. Some ice, but not like up North. 120'' of snow last season and it stuck around, which is unusual. I was packing the driveway by running the X-ICE back and forth.
Nothing can touch the Subaru with snows, but the FWD Maverick should be O.K? I believe the hybrid has traction control, low gear and slippery drive mode. Maybe some cable chains for the occasional 3 foot Nor-Easter.
bcayo
Brad
Probably could, but I don't want to. They use a lot of salt up here on the roads (tough winters). Lots of people put good winter tires on steelies, and use basic lug nuts... to spare the aluminium wheels and chrome lug nuts from corrosion. Looks weird seeing nice newer vehicles with black basic steelies, no hubcaps, but that's the norm up here in winter (lots of people do it).
I've never really thought about it before, but with steel wheels leaving the hub nut exposed, is that something to be concerned about? Doesn't look like anyone is selling center caps for these like come on the stock XL steel wheels.
bcayo
Brad
fordtruckguy
US
ford truck
Hoping to find a set of XL take offs, but I if that doesn’t happen good to know escape steel wheels work despite the offset difference
GreatWhiteNorth
GreatWhiteNorth
Daryl
Winnipeg
2022 XLT
I found my hubs had some light surface rust on 'em (new!), and that was very noticeable with the steel wheels/no center cap. I scrubbed the corrosion with a 3M Scotchbrite pad & WD40, then sprayed the hub recess with anti corrosion compound. Will do it again in spring. They use lots of salt on the roads up here.
The Michelin X-ice snowtires on steelies are working out well, the Maverick performing well in the snow.
Ford Maverick Anyone find a source for factory steel wheels? 20211210_140206
BootXL76
Josh
Arkansas
2022 Maverick XL
If anybody is looking for a set of XL takeoffs with stock tires, mine have less than 50 miles on them with caps, original lug nuts and TPMS sensors…. I’ll let the whole set go for basically what you’d pay Ford for a single steelie (I’m about 25 minutes out of concord, NH and roughly an hour and a half from Boston)
fordtruckguy
US
ford truck
https://www.ebay.com/itm/Pacer-83B-...p2349624.m46890.l6249&mkrid=711-127632-2357-0
17x7 Rim
  • Please Note: standard use uses 60 Degree Conical Seat Lugs
BASIC INFO
  • Style Name: BLACK FWD MOD
    Width: 7 in.
    Diameter: 17 in
    Weight: 34.0 lbs.
    Load Rating: 1500.0 lbs.
    FINISH: Matte Black
    Quantity: 4 PC
CUSTOM INFO
  • Offset: +35 mm
    Bolt Pattern - Standard: 5X4.50 / 5X4.25 in.
    Bolt Pattern - Metric: 5X114.3 / 5X108 mm
    Center Bore: 72
    Center Cap Part Number: N/A
    Back Spacing: 5.38 in.
I was thinking about going with these steelies for winter tires. Closer offset than escape wheels. I’m no wheel expert, is there any reason the ones linked here wouldn’t work?
_Daleyplanit_
Martin
Albany, NY
2023 Ford Maverick Lariat
If anyone has a reliable, affordable source for white steelies (I do love the factory ones but those prices, yikes!) hit me up. I'm thinking of getting on top of next winter's wheelset now :)
