Aftermarket Spray in Bedliner - Drilling
dtanovic
DRagi
Windsor99$
Nissan Rogue
I dropped my Maverick off for a spray in bedliner today at an aftermarket shop. Should I be worried that they will make the same mistake as the Ford plant and drill into the gas tank? Does anyone know how much room there is for drilling out the drain holes? Or which holes are closed to the gas tank?
Oddzball
Arizona
Maverick 2022 XL
I mean I would be VERY worried... did you tell them about it at least?
Oddzball
Arizona
Maverick 2022 XL
Why does anyone need to drill a hole for a spray in bed liner?
Same reason Ford did, to make sure you dont have to re-thread holes for accessories, or the drain holes arent clogged.
Sjbuck2021
Scott
2017 Frontier /2018 Acura RDX
They should plug with rubber plugs along with threaded holes. No drilling involved.
Maverickman74
Shane
Maui HI
Yeah any holes in the bed should be plugged before spraying. Especially threaded ones. And any holes that arent in the bed shouldnt be drilled out, especially near anything critical.
Buschur
Wakeman, Ohio
2020 F150
That's retarded. A small piece of tape works. I did my own, easy.
