Adding one touch window switch to XL
MavVoyeur
VA Beach
VW Jetta
Has anyone tried adding the switch panel from a lariat to a lower trim level and used ForScan to enable the one touch up/down feature to the windows?
I didn't realize how convenient this feature was until I had to go without it. Seems like it should be easy but haven't seen any write-ups yet on the forum.
jsus
2022 Ford Escape Hybrid AWD
snowkarver
BC, Canada
Volvo XC60, XLT Tremor
MavVoyeur
MavVoyeur
VA Beach
VW Jetta
84convertablegt
Aaron
Ohio
2025 Maverick XLT AWD Hybrid
Youtube video coming soon. Added 1 touch up and down to driver and passenger window today for under $100
Ford Maverick Adding one touch window switch to XL 1000019614
TP Mav
Nebraska
2025 Maverick XL AWD
I'd certainly be curious about this. Everything I read said it was expensive and complex to do. Let us know when you have the video!
winghouse1
Randy
MA
25 maverick
Here is the video. Links in the description for the modules. Overall an easy upgrade
Great video. Curious question.. There's so many threads across the boards... If you get the lariat driver's door module for up and down is it plug and play? Or do you need this third party thing?
84convertablegt
Aaron
Ohio
Unfortunately it is not plug and play at all. The 25 and earlier Lariat has a completely different wiring harness and has modules in the doors. The door modules are connected on the canbus Network. While it is theoretically possible to run all new door harnesses and add the modules it would be an insane amount of work when you can accomplish the same thing using aftermarket parts inexpensively.
winghouse1
Randy
MA
25 maverick
That's crazy they decided to use completely different harnesses and such. Adding manufacturing complexity has to add overhead that doesn't seem worth it.
Waterick
Laurens county SC
Maybe that's why the current Lariat 's only have auto down for the driver window.
Top trim adds a lot of features that are worth having bespoke harnesses to accommodate versus wasting unused wiring on the other 75% produced.
