Adding 12v in bed?
john218
Charlotte, NC
Maverick XL, Mercedes C300
I'm a Worx fan, little pricey.
Ford Maverick Adding 12v in bed? 1635934687057
Do you like the Dewalt compressor? I have lots of Dewalt batteries so this might be the ticket for me.
So, I am guessing that if we want to charge our DeWalt (and other brand) batteries out of our cubbies we will have to use the 110 volt cubby to power the battery chargers for them and if so how clean a sign wave does it have? Etc.....
Decayed
yes
a car
Might just lay it on bed/tailgate hinge area with tailgate in "plywood" mode?
Sorry I can't quite picture where you are saying you want to mount the 12v outlet.
Sorry, I thought talk was about placing compressor into cubby for storage while hauling plywood.
SkeeterB
The Woodlands, TX
Vair compressor fits in the under seat space. The one with lighter plug is more convenient than the clips. It now comes in a nice bag. I got mine in a box, more duck tape than cardboard now.
TCK
Jetta Sportwagen
How did we go from 12v to compressors….and why did I buy a compressor? Well, my first truck had one…gonna need that, and Bob’s your uncle
nunucello
Marcello
New York
Here's the 12 volt outlet I installed in the bed. Went with OP suggestion. Mounted on the little access door on drivers side. 1 1/16 hole required and some butt connectors.
That looks perfect. Great job. Confirming that the drill hole saw size is 1-1/16. Would a 1-1/8 size also work ?
Thank You.
SkeeterB
The Woodlands, TX
Thank You.
1 1/16 is a tight fit, but there is a plastic nut on the back. 1 1/8 sb ok.
nunucello
Marcello
New York
Thank you Skeeter. Tight fit sounds better to me for keeping out water, etc.
4t64rd
Miguel
Tampa Bay
23T, '76 Cutlass Cruiser, 2023 Maverick XLT AWD
Same from side to side, wanted to keep the outlets and light safe from mulch and… Stuff, so I bought a second cubby, and an LED RV door light (angled) and some other bits from Amazon 3 panel doohickey with a voltmeter, cigarette lighter outlet and a waterproof switch… Things when wrong, extra holes were drilled but Amazon saved the day which an enderdash plastic thing and it was saved… Angled light toward the bed, and the switch is in the upper area… The RV light has a metal case so it’ll be oK getting hit by my hitch…
Ford Maverick Adding 12v in bed? IMG_3838
Ford Maverick Adding 12v in bed? IMG_3839
Ford Maverick Adding 12v in bed? IMG_3840
Ford Maverick Adding 12v in bed? IMG_3841
bjwnet397
Acworth, Ga
is it possible to get a link to the parts in this image because I would like to convert my 2 12 pre-wired outlets to this? Thank you in advance.
