A quick fix for the rear wheel well debris trap
Thex
Kansas
2022 Maverick Hybrid
I have upgraded to a Elegoo Centauri Carbon - takes 5.5 hours to print each one. Anyone in ICT needing someone to print it for them?
M-ervin
2023 Maverick Tremor
You'd have to be damn near a fool to print and install this. It would obstruct air flow to dry out the rocker. Just rinse it out when you wash the vehicle. It really is as simple as that. 3 winters and there wasn't that much debris in there, so OP is exaggerating. And no OP, you don't need to remove anything to flush this area.
I fabbed mine up 3 years ago. Live in Michigan. I have pulled mine off a few times to check. No issues with “air flow” looks like the day I got it. From 3 years of driving in all season types of driving it’s worth it. With the OP design, appears a quick install and removal if needed to check and clean. Plus the appearance is a plus. Glad yours has stayed clean.
Ford Maverick A quick fix for the rear wheel well debris trap IMG_3794
Rlb080
Jerry
Phoenix, AZ
2014 F150 xlt
Finally finished printing both models. It was a 5+ hour print for each right and left using a Bambu Lab A1. Slipped right end no issues
Ford Maverick A quick fix for the rear wheel well debris trap 20250704_161525[1]
FHFR3Maverick
Chip
Oxford. MI
2022 Maverick Lariat FX4
I took your link to the print file and had a friend make them. They turned out wonderful and look like they will fit perfect. I will install them on my next oil change. I'll post pics when I install them.
nbmav
Kevin
North Bend, WA
2026 Lariat
Why wait? They just slide right in, you don't need to remove the wheels.
