Administrator
Administrator
Staff member
MTC
Fords
KEEPING IT FRESH: NEW FORD REFRESH95 CABIN AIR FILTER CAN HELP IMPROVE VEHICLE INTERIOR AIR QUALITY
Ford Maverick Maverick will get Ford's new Refresh95 advanced cabin air filter Ford Maverick Cabin Air Filter Refresh95-1
DEARBORN, Mich., July 22, 2021 – Starting this year, Ford will roll out all-new standard certified cabin air filters called Ford Refresh95, with plans to cover a majority of its lineup by the end of 2023.
Assembled in the U.S.1, Ford Refresh95 is Ford’s new standard advanced cabin air filter. As air moves through a vehicle’s heating, air conditioning and ventilation system, Ford Refresh95 aims to help reduce microscopic particles that can originate both inside and outside a vehicle’s interior. This is particularly important because, according to the EPA, particles less than 10 microns in diameter, particularly those less than 2.5 microns, pose the greatest risk to health2.
Here are 5 ways Ford Refresh95 certified air filters can help improve vehicle interior air quality:
  1. Filters air particles 30 times smaller than a single human hair: The average human hair is about 70 microns in diameter. Ford Refresh95 certified air filters can help remove at least 95 percent of 2.5-micron size traffic exhaust, organic material, metals and road dust particles3
  2. Helps reduce allergens: Ford Refresh95 certified air filter can trap up to 99 percent of some allergens, including common pollens and dust particles4
  3. Traps bacteria-sized particles: Ford Refresh95 can help reduce airborne concentrations of bacteria-sized particles5
  4. Isolates smog and soot: In dry climates with dust storms or wildfires and urban areas with heavy stop-and-go traffic during commutes, Ford Refresh95 can help filter the particulate matter found in smog and soot5
  5. Laboratory tested: Ford Refresh95 was put through comprehensive third-party lab certification testing, including pressure drop testing to verify Ford Refresh95 will work throughout the recommended service interval6
Ford Refresh95 availability is expected in fourth-quarter 2021 for select vehicles, including the Bronco Sport, Escape, Explorer, Mustang Mach-E, Police Interceptor Utility and Maverick (available Fall 2021).
Down
Jason
Scottsdale, AZ
22 Maverick/02 Z06 Vette
Love hearing this news but I'll reserve a chunk of my excitement until I find out how easy this is to replace.
oljackfrost
Minnesota
K&N makes lifetime cleanable cabin filters. That and their engine air filters are top notch.
NavyBob
TN
2025 Maverick XLT
Problem with FORD OEM FILTERS is that they cost way too much!!! My Ranger filter was $35.00 as a replacement from FORD but I got one on line for less than $10.00. What is this one going to cost from FORD?
Down
Jason
Scottsdale, AZ
JASmith
Jessica
Dodge Ram 1500
If its anything like the Ram 1500, only higher trims will actually get a filter, but you could put a filter in lower trims. Even mine that was pretty loaded, they left a spot for the air filter, but no actual filter installed, just use cheap aftermarket ones replaced once a year.
flashfearless
Alan
2022 Ford Mav Lariat Hybrid,2014 Ford Edge Limited
All Ford Vehicles get a cabin filter
balucipher
Balu
Coral Springs, FL
2021 Gladiator, 2021 Tesla Model Y
Particulate air filter on all trims of the Maverick
jimmy fitzwell
jimmy
troy, mt.
73 pinto wagon, 67 olds 98
95% filtration of 2.5 micron particulate is excellent! I would recommend against the cheap ones, which may not be anywhere near that good. Screw Amazon and all the Chinese junk Bezos peddles!
However, I may run a more basic filter, or none at all in the winter. I live way up in the sticks, not many chemicals floating about.
