- First Name
- Troy
- Nov 3, 2025
- Granite Quarry, NC
- 2025 Ford Maverick Lobo (LOW) & 2003 F-150 Super Crew Lariat 4.6L V8 2v
- Engine
- 2.0L EcoBoost
Hello Everyone,
I wanted to post my experience with doing a drain & refill on my LOBO, the results were a bit surprising.
I'd highly recommend changing the fluid no later than 10K to get the break-in metals out of the transmission, I've posted videos here about my PTU and RDU which both had metal in them as well. If you want to keep your Maverick longer than the Warranty Period keep up on your fluid changes.
My Maintenance so far on the Maverick:
500 miles - Break-in oil change done, metal found but not excessive, had fuel smell to the oil.
2000 Miles - Oil change done, less metal found oil was a bit darker than the 500 mile oil change but still clean. No Fuel smell noted.
5000 Miles - Engine Oil change done, PTU & RDU Drain & Refill - Found Metal in both PTU & RDU, slightly less metal in the engine oil at 2,000 miles, no fuel smell.
10,0000 Miles - Engine oil change done, NO METAL in the engine oil! Transmission drain & refilled, metal observed, trans fluid was dark.
I plan to do another Transmission, PTU & RDU service at 30K and change my oil every 5K from then on, just curious on what you all do here?
Thanks!
Troy.
Thanks!
Troy.
I was really starting to get nervous, it's been 2 days now since the last oil change post.
