Ryan M
Ryan
Ohio
2024 Ford Maverick XL
I found a subwoofer box on Amazon that would fit underneath my rear seat, although I did have to remove the plastic trim that was underneath and make the hole slightly larger to fit my sub, nonetheless I am extremely pleased with the completed build. I used a line output converter to get signal and tapped into the front speakers underneath the kick panels to get the signal, because I’ve been advised the rear signal does not have bass frequencies.I do plan on adding another amplifier from CT sounds either the 80.4d or the 150.4 d to power the 4 kicker CS series speaker I installed in my doors and rear pillars previously
LMK if you have any questions or suggestions
Ford Maverick 8 inch CT Sounds Subwoofer Install + Speaker Installs IMG_5313
Ford Maverick 8 inch CT Sounds Subwoofer Install + Speaker Installs IMG_5306
Ford Maverick 8 inch CT Sounds Subwoofer Install + Speaker Installs IMG_5304
Ford Maverick 8 inch CT Sounds Subwoofer Install + Speaker Installs IMG_5308
Ford Maverick 8 inch CT Sounds Subwoofer Install + Speaker Installs IMG_5307
Ford Maverick 8 inch CT Sounds Subwoofer Install + Speaker Installs IMG_5310
Ford Maverick 8 inch CT Sounds Subwoofer Install + Speaker Installs IMG_5309
Ryan M
Ryan M
Ryan
Ohio
Here are links to everything I used
Amplifier -https://www.ctsounds.com/collections/ct-series-amplifiers/products/ct-400-1d
Price - $119.99 (on sale)
Subwoofer (2ohm model) - https://www.ctsounds.com/products/hydro-8
Price - $89.99 (on sale)
Active Line Output Converter - https://www.ctsounds.com/products/ct-lc2
Price -$42 (on sale)
Wiring Kit - https://www.ctsounds.com/collections/4-gauge-amp-kit/products/4ga-elite
Price - $79.99 (on sale)
Speaker Wire - https://a.co/d/0WlZgua
Price - $26.34
Subwoofer Enclosure(Had to cut hole larger to fit sub) - https://a.co/d/fEbX7HG
Price - $48
Posi -Tap - https://a.co/d/iiAmVby
Price - $9.90
Inline Fuse Holder (for LOC) - https://a.co/d/dREGx9V
Price - $4.99
Fuse (For LOC) - https://a.co/d/aDlfcb2 (1A Model)
Price - $4.99
Wire (For LOC) - https://a.co/d/ihBznfJ
Price - $7.99
Wire Ferules - https://www.amazon.com/dp/B097ZNCKM...n_lstpd_RW6F63P1WZP6C8F60VND_3&language=en-US
Price - $9.99 (on sale)
Heat Shrink - https://www.harborfreight.com/heat-shrink-tubing-assortment-with-case-140-piece-70172.html
Price - $6.99
Wire Connectors https://www.harborfreight.com/terminal-connector-set-500-piece-70214.html
Price - $14.99
Ryan M
Ryan M
Ryan
Ohio
Here are the Speakers I installed, I highly recommend ordering from Crutchfield they provide you with everything you need to install. Even without an amp they still sound amazing. While installing be sure you get the bolt out of the door that is underneath the reflector. And as for the rear be extremely careful removing the speaker housing because there are 2 tabs that can break very easily. I suggest you watch a YouTube video and take a look at the instructions Crutchfield gives you.
Ford Maverick 8 inch CT Sounds Subwoofer Install + Speaker Installs IMG_2156
Ford Maverick 8 inch CT Sounds Subwoofer Install + Speaker Installs IMG_1639
Ford Maverick 8 inch CT Sounds Subwoofer Install + Speaker Installs IMG_1636
Ford Maverick 8 inch CT Sounds Subwoofer Install + Speaker Installs IMG_1635
Ford Maverick 8 inch CT Sounds Subwoofer Install + Speaker Installs IMG_1600
Ford Maverick 8 inch CT Sounds Subwoofer Install + Speaker Installs IMG_2152
Ford Maverick 8 inch CT Sounds Subwoofer Install + Speaker Installs IMG_2158
Ford Maverick 8 inch CT Sounds Subwoofer Install + Speaker Installs IMG_2157
Ford Maverick 8 inch CT Sounds Subwoofer Install + Speaker Installs IMG_2106
Ford Maverick 8 inch CT Sounds Subwoofer Install + Speaker Installs IMG_2104
Pappamoto
Ken
2025 Ford Maverick Hybrid Lariat Shadow Black w/BAP
I upgraded the back speakers in the pillars and the sound that goes to them is just bad. Unfortunately, I'm only a plug and play person, so wouldn't know how to install an audio processor/amp, so I just fade towards the front.
Ryan M
Ryan M
Ryan
Ohio
I wonder if ForScan could make the sound in the rear better
Carlitos_92
Yes. There is a "flat eq" setting that needs to be changed in Forscan.
Ryan M
Ryan M
Ryan
Ohio
Pappamoto
Ken
I have the B&O and thought that it was already set to flat.
Ryan M
Ryan M
Ryan
Ohio
I’m not sure on the B&O, I had the base sound system which I know has a factory EQ to protect those cheap factory speakers they install
Pappamoto
Ken
I have the B&O & checked the EQ settings in FORSCAN & it was already set to flat.
So even though its set to flat, the audio to the rear speakers is totally different than what is going to the fronts. I tried the surround setting and it's a lot worse. The rears then sound like an echo. Really bad.
Cancunbadlands
Cancun
Cancun
Nice set up for a budget
Darthie
Frank
Fantastic. Thanks for taking the time to add the links.
FordDiehard
Paul
Central VA
2017 Ford Focus, 2023 Maverick Lariat
I too have the B&O system. Although there have been many comments in various threads about the inadequacies of the factory speakers, but for the type of music I enjoy, the factory sound is fine. I'm sure when the time comes to replace them, I'll upgrade at that point.
I stopped at the Crutchfield outlet store in Charlottesville many years ago and bought speakers for a previous vehicle.
