5k miles, having intermittent AC issues check engine light
LittleNeckLightning
Queens NY
www.mobileguitars.com
Ford Maverick XLT FX4 Luxury
Last week my AC went out for about 20 minutes, thought it was a fluke. It went out for about an hour today and now it’s back and check engine light is on. Ford pass ap says I might have an “electrical issue”. Combined with the recalls, seatbelt warning, infotainment really sucking, I’m starting to get really annoyed with these issues. Any insight on this AC issue would be helpful, thx!
Montana
What are the codes it's throwing?
710-oil-614
Cal
2025 Hybrid AWD Lariat
Bwicka
Lakeside,ca.
If you hit anything out front and messed up the outside temp probe on left side front bumper , down lower grill . Can affect a/c cycle and operation . May check wire harness plug to bumper cover at passenger side front wheel well . 6 wire plug goes to 2 lower markers and temp sensor . Have heard of people having a bad connection/corrosion issue on that plug.check , use a little dielectric grease and replug . Only do this if reading code on temp sensor out of range or similar .
Or take it in if still under 36,000 miles
