53Q 4k tow Transmission cooler confirmation
lsxmalibu
Chad
Wisconsin
2025 xl
I was under the assumption the 4k towing had two transmission coolers. One smaller heat exchanger mounted on the transmission and an air cooled cooler mounted on the front radiator. I checked my new 2025 2.0, awd and I only have the cooler mounted on the transmission.
The 53Q option states...Aux auto Trans cooler.
Ford Maverick 53Q 4k tow Transmission cooler confirmation 20250927_133816
Ford Maverick 53Q 4k tow Transmission cooler confirmation Screenshot_20250928_091920_Gallery
CarbonGrayFX4
Luke
Virginia
2024 Carbon Gray XLT FX4
Are you saying Ford shorted you a transmission oil cooler? Are you sure the cooler mounted on the radiator about mid way up is not there? That would be a major blunder on Ford's part. Seems unlikely.
lsxmalibu
Chad
Wisconsin
2025 xl
Im asking if others with a 2025 with 4k towing have two transmission coolers.....I only have one as seen in the picture. There is nothing near the radiator.
awpitt
Tony
Maryland
2025 Ford Maverick
I think the auxiliary cooler means that the transmission cooler for the 4k tow is larger than the regular one.
lsxmalibu
Chad
Wisconsin
2025 xl
All im going by is what people are saying online. If you look at parts diagrams the cooler setup on my truck says "less towing" and the other setup with two coolers says "towing package 1"
Ford Maverick 53Q 4k tow Transmission cooler confirmation 20250929_062139
Ford Maverick 53Q 4k tow Transmission cooler confirmation 20250929_062120
Carlitos_92
Are you 100% sure you have the 4K towing package? Do you have both 4- and 7-pin electrical connectors at the hitch?
Edit: Also, the aux cooler is sandwiched between the radiator and A/C condenser, so it is not something you're going to casually glance at. If you haven't taken off any parts, it's probably still hidden from view.
lsxmalibu
Chad
Wisconsin
2025 xl
Yes I have 4k. 7 pin connector....4 pin connector....trailer brakes....
I know where the rad mounted cooler would be and you can see just by looking at my cooler its the wrong heat exchanger for the rad mounted cooler. The radiator mounted cooler uses the smaller 6 port cooler....you'd see the added 2 ports and lines.
RR - All the way
GA
I see you are using diagrams for the offroad FX4. I have no idea, but would the 4K towing package differ if the vehicle is not FX4???
lsxmalibu
Chad
Wisconsin
2025 xl
Possible. I just entered my vehicle specs.
Ford Maverick 53Q 4k tow Transmission cooler confirmation 20250929_094140
Tbone289
That would be a strange way to describe it since "auxilliary" is synonymous with "supplemental". In model year '22-'24 Mavericks, that's exactly what it was--a smaller water-to-oil cooler with a supplemental/auxiliary air-to-oil cooler.
It appears that the OP's 4K tow package doesn't have a supplemental air-to-oil cooler and has the larger water-to-oil cooler that the standard (non-4K) '22-'24 has.
It didn't, at least prior to 2025. 4K tow Mavericks had a supplemental air-to-oil cooler regardless of FX4 package or not.
lsxmalibu
Chad
Wisconsin
2025 xl
Auxiliary means more than one....secondary. its listed on the 2025 towing spec sheet
Ford Maverick 53Q 4k tow Transmission cooler confirmation Screenshot_20250929_100655_Gallery
Tbone289
@lsxmalibu, it sure seems to me from your picture that they put the standard, larger, heat exchanger on your 4K tow Maverick without the auxiliary cooler.
In my picture below, marked in red you can see the oil lines to the auxiliary cooler on a 2024 4K below the upper radiator hose (just for comparison):
Ford Maverick 53Q 4k tow Transmission cooler confirmation 1759159153860-d
lsxmalibu
Chad
Wisconsin
2025 xl
Yes. I have the 4 port cooler. The cooler for the front mounted cooler would have the added 2 ports like you have marked. Not sure if this is a 2025 new thing? I called the dealer. Waiting for a reply
CMYSIX
Quinn
Opelika Al.
2025 Maverick
but you don't have a 4X4 do you? AWD is not 4X4, but I'm with the others you can't see the other cooler.
RR - All the way
GA
This! Ford verbiage is misleading but auxiliary can mean "providing supplemental or additional support. I guess in this case Ford PR people are using this term because the larger cooler provides additional cooling capability over the regular size cooler. Does not necessarily mean "secondary". If this is the case, the more "honest" description would have been just "larger"!!!!
I have the 4k also and I presumed there were two coolers also!!!!
